CCS: CCS6.0
I have had some trouble with the CLA in regards to reading ADC values. I started my code based off of the ClaAdc example which originally,I adapted this example to read 3 adc values into simple integer variables, I then tried to store these values in 3 (adc) x 20 (array size) arrays, and this is where I ran into trouble. The values in the 1st array would update, however the others were not correct. I also tried adjusting the frequency of cla interrupts called, but this did not have any affect. The cla code is posted below.
_Cla1Task2:     MMOVZ16    MR0,  @_ConversionCount                ;1 Current Conversion     ;Ch0     MMOV16     MAR1, MR0, #_Ch0                       ;2 Point MAR1 register to Ch0[ConversionCount]     MNOP                                              ;3 wait     MNOP                                              ;4 wait     MNOP                                              ;5 wait     MNOP                                              ;6 wait     MNOP                                              ;7 Wait till I8 to read result     MMOVZ16    MR2,  @_AdcResult.ADCRESULT0           ;8 Read ADCRESULT0     MMOV16     *MAR1, MR2                             ;9 Store ADCRESULT0 using pointer to Ch0[ConversionCount]     ;Ch1     MMOV16     MAR1, MR0, #_Ch1                       ;2 Point MAR1 register to Ch1[ConversionCount]     MNOP                                              ;3 wait     MNOP                                              ;4 wait     MNOP                                              ;5 wait     MNOP                                              ;6 wait     MNOP                                              ;7 Wait till I8 to read result     MMOVZ16    MR2,  @_AdcResult.ADCRESULT0           ;8 Read ADCRESULT1     MMOV16     *MAR1, MR2                             ;9 Store ADCRESULT1 using pointer to Ch1[ConversionCount]     ;Ch2     MMOV16     MAR1, MR0, #_Ch2                       ;2 Point MAR1 register to Ch1[ConversionCount]     MNOP                                              ;3 wait     MNOP                                              ;4 wait     MNOP                                              ;5 wait     MNOP                                              ;6 wait     MNOP                                              ;7 Wait till I8 to read result     MMOVZ16    MR2,  @_AdcResult.ADCRESULT0           ;8 Read ADCRESULT1     MMOV16     *MAR1, MR2                             ;9 Store ADCRESULT1 using pointer to Ch1[ConversionCount]
    MADDF32    MR0, MR0, #1.0                         ; Add 1 to ConversionCount     MCMPF32    MR0, #NUM_DATA_POINTS.0                ; Compare ConversionCount to max     MF32TOUI16 MR0, MR0                               ; Convert count to Uint16     MNOP     MNOP     MBCNDD     _RestartCount, GEQ                     ; If count >= NUM_DATA_POINTS     MMOVIZ     MR1, #0.0                              ; Preload MR1 with 0     MNOP     MNOP     MMOV16     @_ConversionCount, MR0                 ; If branch not taken, store current count     MSTOP _RestartCount     MMOV16     @_ConversionCount, MR1                 ; If branch taken, restart count     MSTOP     MNOP     MNOP     MNOP _Cla1T2End:
Is there anyone help? thank u
