Part Number: TMS320F28035
hello sir/Madam,
there are 2 interrupts used in my project, one is the timer 0 which generate INT1 to CPU has a CPU priority 5.
the other one is EPWM_INT which generate INT4 to CPU has a CPU priority 7.
for some reason, INTM is cleared during the timer0 ISR, and then i found that this ISR will be interrupted by ISR of EPWM_INT.
how that a ISR with lower priority could interrupt another one with a higher priority?
Can you tell me what's the problem here? thank you very much.
