Other Parts Discussed in Thread: LAUNCHXL-F28027F, C2000WARE
I am using 2 external interrupts to find distance covered by an encoder and a timer at 40 hertz which runs pid to maintain some constant velocity . It doesn't respond if thr input is more than a certain velocity.
CPU_enableInt(myCpu, CPU_IntNumber_1) is used by both interrupts and timer . Can that be an issue?
here is the outline of the code-
#include "DSP28x_Project.h"
#include "common/include/adc.h"
#include "common/include/clk.h"
#include "common/include/flash.h"
#include "common/include/gpio.h"
#include "common/include/pie.h"
#include "common/include/pll.h"
#include "common/include/cap.h"
#include "common/include/wdog.h"
#include "common/include/timer.h"
#include "IQmathLib.h"
#define RANGE_SPEED 2500
__interrupt void xint1_isr(void);
__interrupt void xint2_isr(void);
__interrupt void cpu_timer0_isr(void);
// Function Prototypes
void scia_echoback_init(void);
void scia_fifo_init(void);
void scia_xmit(int a);
void scia_msg(char *msg);
uint16_t direction = 0;
unsigned long CMD;
float asd;
ADC_Handle myAdc;
CLK_Handle myClk;
FLASH_Handle myFlash;
GPIO_Handle myGpio;
PIE_Handle myPie;
TIMER_Handle myTimer;
// Globals
Uint16 ReceivedChar=0;
uint32_t pwmdata=0,pwm1=0;
#define DELAY (CPU_RATE/1000*6*510) //Qual period at 6 samples
volatile signed short lookup = 0; ///<find encoder direction
signed long iAngle = 0,StartAngle=0, AngleTravelled=0,TotalAngle=0,PreviAngle=0,Speed=0,targetangle=0; ///<curent position wrt initial position
int Acceleration=2;
uint16_t gpiodata1,gpiodata2;
unsigned char ab = 0; ///<read encoder pins
unsigned char pidflag=0,flag=1;
//float kp,ki,kd,previousvalue;
//int MAX_SPEED=100;
int32_t sumerror,differror,error,previouserror;
signed long MAX_SPEED=0,PREV_MAX_SPEED=0,savediangle,savedpreviangle,SpeedActual=0,up;
static signed long counter=0;
float pidpwm;
typedef struct { _iq Cmd; // Input: Reference input
_iq Fbk; // Input: Feedback input
_iq Err; // Variable: Error
_iq Kp; // Parameter: Proportional gain
_iq Up; // Variable: Proportional output
_iq Ui; // Variable: Integral output
_iq Ud; // Variable: Derivative output
_iq OutPreSat; // Variable: Pre-saturated output
_iq OutMax; // Parameter: Maximum output
_iq OutMin; // Parameter: Minimum output
_iq Out; // Output: PID output
_iq SatErr; // Variable: Saturated difference
_iq Ki; // Parameter: Integral gain
_iq Kc; // Parameter: Integral correction gain
_iq Kd; // Parameter: Derivative gain
_iq Up1; // History: Previous proportional output
} PIDREG3;
typedef PIDREG3 *PIDREG3_handle;
#define PIDREG3_DEFAULTS { 0, \
0, \
0, \
_IQ(0.2), \
0, \
0, \
0, \
0, \
_IQ(+1000), \
_IQ(-1000), \
0, \
0, \
_IQ(0.0), \
_IQ(0.0), \
_IQ(0.0), \
0, \
PIDREG3 Motor = PIDREG3_DEFAULTS;
// Main
CAP_Handle myCap;
void main(void)
char *msg;
CPU_Handle myCpu;
PLL_Handle myPll;
WDOG_Handle myWDog;
// Initialize all the handles needed for this application
myAdc = ADC_init((void *)ADC_BASE_ADDR, sizeof(ADC_Obj));
myClk = CLK_init((void *)CLK_BASE_ADDR, sizeof(CLK_Obj));
myCpu = CPU_init((void *)NULL, sizeof(CPU_Obj));
myFlash = FLASH_init((void *)FLASH_BASE_ADDR, sizeof(FLASH_Obj));
myGpio = GPIO_init((void *)GPIO_BASE_ADDR, sizeof(GPIO_Obj));
myPie = PIE_init((void *)PIE_BASE_ADDR, sizeof(PIE_Obj));
myPll = PLL_init((void *)PLL_BASE_ADDR, sizeof(PLL_Obj));
myCap = CAP_init((void *)CAPA_BASE_ADDR, sizeof(CAP_Obj));
myWDog = WDOG_init((void *)WDOG_BASE_ADDR, sizeof(WDOG_Obj));
myTimer = TIMER_init((void *)TIMER0_BASE_ADDR, sizeof(TIMER_Obj));
// Perform basic system initialization
WDOG_disable(myWDog);
CLK_enableAdcClock(myClk);
(*Device_cal)();
// CLK_disableAdcClock(myClk);
// Select the internal oscillator 1 as the clock source
CLK_setOscSrc(myClk, CLK_OscSrc_Internal);
// Setup the PLL for x10 /2 which will yield 50Mhz = 10Mhz * 10 / 2
PLL_setup(myPll, PLL_Multiplier_10, PLL_DivideSelect_ClkIn_by_2);
// Disable the PIE and all interrupts
PIE_disable(myPie);
PIE_disableAllInts(myPie);
CPU_disableGlobalInts(myCpu);
CPU_clearIntFlags(myCpu);
#ifdef _FLASH
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
#endif
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the f2802x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initialize GPIO:
// This example function is found in the f2802x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
InitGpio();
// For this example, only init the pins for the SCI-A port.
// This function is found in the f2802x_Sci.c file.
InitSciaGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the f2802x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in f2802x_DefaultIsr.c.
// This function is found in f2802x_PieVect.c.
InitPieVectTable();
EnableInterrupts();
// Step 4. Initialize all the Device Peripherals
// Not required for this example
// Step 5. User specific code
InitCpuTimers();
GPIO_setPullUp(myGpio, GPIO_Number_19, GPIO_PullUp_Enable);
GPIO_setQualification(myGpio, GPIO_Number_19, GPIO_Qual_Sync);
GPIO_setMode(myGpio, GPIO_Number_19, GPIO_19_Mode_ECAP1);
GPIO_setMode(myGpio, GPIO_Number_34, GPIO_34_Mode_GeneralPurpose);
GPIO_setDirection(myGpio, GPIO_Number_34, GPIO_Direction_Output);
GPIO_setPullUp(myGpio,GPIO_Number_34 , GPIO_PullUp_Enable);
PIE_setDebugIntVectorTable(myPie);
PIE_enable(myPie);
CLK_enableEcap1Clock(myClk);
CAP_setModeApwm(myCap); // Enable APWM mode
CAP_setApwmPeriod(myCap, 0x9C4); // Set Period value
// CAP_setApwmCompare(myCap,0x4E2); // Set Compare value
CAP_clearInt(myCap, CAP_Int_Type_All); // Clear pending interrupts
CAP_enableInt(myCap, CAP_Int_Type_CTR_CMP); // enable Compare Equal Int
// scia_fifo_init(); // Initialize the SCI FIFO
// scia_echoback_init(); // Initialize SCI for echoback
// Start counters
CAP_enableTimestampCounter(myCap);
PIE_registerPieIntHandler(myPie, PIE_GroupNumber_1, PIE_SubGroupNumber_7,
(intVec_t)&cpu_timer0_isr);
// Configure CPU-Timer 0 to interrupt every 500 milliseconds:
// 60MHz CPU Freq, 50 millisecond Period (in uSeconds)
//ConfigCpuTimer(&CpuTimer0, 60, 500000);
TIMER_stop(myTimer);
TIMER_setPeriod(myTimer, 1250000);
TIMER_setPreScaler(myTimer, 0);
TIMER_reload(myTimer);
TIMER_setEmulationMode(myTimer,
TIMER_EmulationMode_StopAfterNextDecrement);
TIMER_enableInt(myTimer);
TIMER_start(myTimer);
PIE_registerPieIntHandler(myPie, PIE_GroupNumber_1, PIE_SubGroupNumber_4,
(intVec_t)&xint1_isr);
PIE_registerPieIntHandler(myPie, PIE_GroupNumber_1, PIE_SubGroupNumber_5,
(intVec_t)&xint2_isr);
PIE_enableInt(myPie, PIE_GroupNumber_1, PIE_InterruptSource_XINT_1);
PIE_enableInt(myPie, PIE_GroupNumber_1, PIE_InterruptSource_XINT_2);
CPU_enableInt(myCpu, CPU_IntNumber_1);
PIE_enableTimer0Int(myPie);
// Enable Global Interrupts
CPU_enableGlobalInts(myCpu);
// CPU_enableDebugInt(myCpu);
// GPIO0 and GPIO1 are inputs
GPIO_setMode(myGpio, GPIO_Number_6, GPIO_6_Mode_GeneralPurpose);
GPIO_setDirection(myGpio, GPIO_Number_6, GPIO_Direction_Input);
GPIO_setQualification(myGpio, GPIO_Number_6, GPIO_Qual_Sample_3);
GPIO_setMode(myGpio, GPIO_Number_7, GPIO_7_Mode_GeneralPurpose);
GPIO_setDirection(myGpio, GPIO_Number_7, GPIO_Direction_Input);
GPIO_setQualification(myGpio, GPIO_Number_7, GPIO_Qual_Sample_3);
GPIO_setQualificationPeriod(myGpio, GPIO_Number_7, 0x80);
GPIO_setQualificationPeriod(myGpio, GPIO_Number_6, 0x80);
// GPIO0 is XINT1, GPIO1 is XINT2
GPIO_setExtInt(myGpio, GPIO_Number_6, CPU_ExtIntNumber_1);
GPIO_setExtInt(myGpio, GPIO_Number_7, CPU_ExtIntNumber_2);
// Configure XINT1
PIE_setExtIntPolarity(myPie, CPU_ExtIntNumber_1,
PIE_ExtIntPolarity_RisingAndFallingEdge);
PIE_setExtIntPolarity(myPie, CPU_ExtIntNumber_2,
// Enable XINT1 and XINT2
PIE_enableExtInt(myPie, CPU_ExtIntNumber_1);
PIE_enableExtInt(myPie, CPU_ExtIntNumber_2);
msg = "\r\n\n\nHello World!\0";
scia_msg(msg);
msg = "\r\nYou will enter a character, and the DSP will echo it back!\n\0";
scia_msg(msg);
for(;;)
// Wait for inc character
while(SciaRegs.SCIFFRX.bit.RXFFST !=1)
// main calculation
// scia_echoback_init - Test 1,SCIA DLB, 8-bit word, baud rate 0x000F, default
// 1 STOP bit, no parity
void
// Note: Clocks were turned on to the SCIA peripheral
// in the InitSysCtrl() function
// 1 stop bit, No loopback, No parity, 8 char bits, async mode,
// idle-line protocol
SciaRegs.SCICCR.all =0x0007;
// enable TX, RX, internal SCICLK, Disable RX ERR, SLEEP, TXWAKE
SciaRegs.SCICTL1.all =0x0003;
SciaRegs.SCICTL2.all =0x0003;
SciaRegs.SCICTL2.bit.TXINTENA =1;
SciaRegs.SCICTL2.bit.RXBKINTENA =1;
// SCI BRR = LSPCLK/(SCI BAUDx8) - 1
#if (CPU_FRQ_60MHZ)
SciaRegs.SCIHBAUD = 0x0000; // 9600 baud @LSPCLK = 15MHz(60 MHz SYSCLK)
SciaRegs.SCILBAUD = 0x00C2;
#elif (CPU_FRQ_50MHZ)
SciaRegs.SCIHBAUD = 0x0000; // 9600 baud @LSPCLK = 12.5 MHz(50 MHz SYSCLK)
SciaRegs.SCILBAUD = 0x00A1;
#elif (CPU_FRQ_40MHZ)
SciaRegs.SCIHBAUD = 0x0000; // 9600 baud @LSPCLK = 10MHz(40 MHz SYSCLK)
SciaRegs.SCILBAUD = 0x0081;
#endif
SciaRegs.SCICTL1.all =0x0023; // Relinquish SCI from Reset
// scia_xmit - Transmit a character from the SCI
void
scia_xmit(int a)
while (SciaRegs.SCIFFTX.bit.TXFFST != 0)
SciaRegs.SCITXBUF=a;
// scia_msg -
void
scia_msg(char * msg)
int i;
i = 0;
while(msg[i] != '\0')
scia_xmit(msg[i]);
i++;
// scia_fifo_init - Initialize the SCI FIFO
void
scia_fifo_init()
SciaRegs.SCIFFTX.all=0xE040;
SciaRegs.SCIFFRX.all=0x2044;
SciaRegs.SCIFFCT.all=0x0;
// xint1_isr -
__interrupt void
xint1_isr(void)
// xint2_isr -
__interrupt void
xint2_isr(void)
__interrupt void
// End of File
