Part Number: TMS320F28377S
HOW TO MAKE SURE THAT TWO ePWM MODULES RUN SIMULTANEOUSLY WHICH MEANS TWO COUNTERS MAINTAIN THE SAME VALUE AT EVERY MOMENT WHEN THEY ARE SET UP EXACTLY THE SAME?
Hi Wentao,
If you want to use the sync in/out pulses to synchronize some load events, then take a look at the diagram "Time-Base Counter Synchronization Scheme" in the TRM (
) This will tell you how all the ePWMs sync signals are connected together and if you need to write any mux settings to connect your specific ePWM modules.
The diagram "Simplified ePWM Module" also gives a good idea of what events can generate the sync output signal.
