Other Parts Discussed in Thread: CONTROLSUITE
Hello all,
I've met a weird problem when using Epwm Tripzone.
In my application, TZ1 is simply set to lock Epwm1&2 and Epwm1&2 is set output directly.
The phenomenon is:
If tripzone function is enabled, when first time power on, TZ will be trigged. Then if I manually reset the LAUNCHPAD, TZ will not be trigged and Epwm output normally.
If tripzone function is disabled, when firsttime power on, Epwm of course output normally.
Has anyone met the same problem? What is the problem probably located in? Is there any required sequence when initializing Epwm and TZ function?
Thanks a lot!
