CCS/TMS320F28069: Priority of interrupts
Part Number: TMS320F28069
If I am using more than one interrupt in my application( like timer and UART) . What will be the default priority of those interrupt
  • Devvrat,
    Please see the F2806x Technical Reference Manual (SPRUH18), starting on page 176, tables 1-119 and 1-120:
    www.ti.com/lit/spruh18.pdf
    Also, to learn more about the F2806x interrupt please see the F2806x workshop at:
    processors.wiki.ti.com/.../C2000_Archived_Workshops
    I hope this helps. If this answers your question, please click the green "Verified Answer" button. Thanks.
    - Ken
  • Devvrat,
    Interrupt priority is documented in the device datasheet. For the PIE, interrupt group 1 is highest priority. Within a group, interrupt 1 is highest priority.
    However, understand that priority only applies when more than one interrupt is pending at the same time. Once you are in an ISR, ANY enabled interrupt can interrupt that ISR. By default, global interrupt enable (INTM bit) is disabled when entering an ISR. To nest interrupts, you need to enable any desired interrupts, disable all other interrupts (using IER and PIEIER registers), and then re-enable global interrupts.
    David
  • Devvrat,
    Sorry, the link to the document should be:
    - Ken
  • Devvrat,
    I haven’t heard from you for a while, so I’m assuming you were able to resolve your issue. If this isn’t the case, please reject this resolution or reply to this thread. If this thread locks, please make a new thread describing the current status of your issue.
    - Ken
