Part Number: TMS320F28377D
Other Parts Discussed in Thread: CONTROLSUITE, C2000WARE
Dears:
We follow the before issue to check :e2e.ti.com/.../678896
We check the Sector F to erase the memory which is OK using CCS on-chip Flash.
And we debug the application program through the DFU (kernel 190) step by step, and we find the program only wrote the memory at 64 bits intervals.
We thought it is the key problem.
Then we use CCS to write the txt file to Flash directly, and the written memory as below picture:
Why do the issue happen?
We use the kernel file under C:\ti\controlSUITE\device_support\F2837xD\v190
Could you kindly help to give some advice?
Thanks a lot!
Best regards
Luck Wu
