Part Number: TMS320F28375S
HI Sir:
We find that The TMS320F28375S PIN 151 IO-PIN When i set it out Low. But sometimes it can be changed by External factors. it means i set low ,but sometimes the PIN out is high.
HI Sir:
I believe this damages the device. You will need to use an external buffer capable of handling this. Shorting the opposite polarity voltage to our IO (Set as output) with a powerful enough source to pass the 20 mA limit will damage the device.
