Part Number: TMS320F28377D
Other Parts Discussed in Thread: CCSTUDIO
Good morning.
I configuring CCStudio to develop two project with target config file (ccxml) for code loading in FLASH, FLASH_STANDALONE (CPU1) e RAM in either CPU (CPU1 & CPU2 - F2837xD). I can use the emulator XDS100V2 for CPUs debuggin. My code is grown with same extensive state machine that using a few goto istruction and label to create a state transition, entry point and round checking.
What I obtain is a very strange situation. The code of CPU2, when loaded togheter CPU1's code, starts to run immediately while CPU1 waiting an emulator run command: if I block CPU2, code break at address 0x3fe00a with no debug information available. I eliminate same code for reduce the lenght of CPU2's code. Now CPU2's code is loaded correctly and I can lunch that with emulator also for debuggin (step by step).
Unfortunately, I must continue to develop CPU2s code, so I want to resolve this tedious problem. I take care of map file but I don't see anythings: after all, linker must give an error if there will be a issue with code or stack dimension.
Is there sameone that have an idea for same ispections? Thank's a lot.
Regards.
Diego.
P.S.: I attach my map file for CPU2. I forgot that CPU1 and CPU2 use a shared ram to pass info.
TMS320C2000 Linker PC v18.1.1
>> Linked Mon Jun 4 07:48:16 2018
OUTPUT FILE NAME: <28377D_CPU2-Board_Testing.out>
ENTRY POINT SYMBOL: "code_start" address: 00000000
MEMORY CONFIGURATION
name origin length used unused attr fill
PAGE 0:
BEGIN 00000000 00000002 00000002 00000000 RWIX
RAMM0 00000122 000002de 00000154 0000018a RWIX
RAMLS4_LS5 0000a000 00001000 00000000 00001000 RWIX
RAMD0 0000b000 00000800 00000800 00000000 RWIX
RAMD1 0000b800 00000800 000007fe 00000002 RWIX
RAMGS0 0000c000 00001000 00000064 00000f9c RWIX
RAMGS1 0000d000 00001000 00000000 00001000 RWIX
RAMGS2 0000e000 00001000 00000000 00001000 RWIX
RAMGS3 0000f000 00001000 00000000 00001000 RWIX
RAMGS4 00010000 00001000 00000000 00001000 RWIX
RESET 003fffc0 00000002 00000000 00000002 RWIX
PAGE 1:
BOOT_RSVD 00000002 00000120 00000000 00000120 RWIX
RAMM1 00000400 00000400 00000100 00000300 RWIX
ADCA_RESULT 00000b00 00000020 00000018 00000008 RWIX
ADCB_RESULT 00000b20 00000020 00000018 00000008 RWIX
ADCC_RESULT 00000b40 00000020 00000018 00000008 RWIX
ADCD_RESULT 00000b60 00000020 00000018 00000008 RWIX
CPU_TIMER0 00000c00 00000008 00000008 00000000 RWIX
CPU_TIMER1 00000c08 00000008 00000008 00000000 RWIX
CPU_TIMER2 00000c10 00000008 00000008 00000000 RWIX
PIE_CTRL 00000ce0 00000020 0000001a 00000006 RWIX
PIE_VECT 00000d00 00000200 000001c0 00000040 RWIX
DMA 00001000 00000200 000000e0 00000120 RWIX
CLA1 00001400 00000040 0000003e 00000002 RWIX
CLA1_MSGRAMLOW 00001480 00000080 00000000 00000080 RWIX
CLA1_MSGRAMHIGH 00001500 00000080 00000000 00000080 RWIX
EPWM1 00004000 00000100 00000100 00000000 RWIX
EPWM2 00004100 00000100 00000100 00000000 RWIX
EPWM3 00004200 00000100 00000100 00000000 RWIX
EPWM4 00004300 00000100 00000100 00000000 RWIX
EPWM5 00004400 00000100 00000100 00000000 RWIX
EPWM6 00004500 00000100 00000100 00000000 RWIX
EPWM7 00004600 00000100 00000100 00000000 RWIX
EPWM8 00004700 00000100 00000100 00000000 RWIX
EPWM9 00004800 00000100 00000100 00000000 RWIX
EPWM10 00004900 00000100 00000100 00000000 RWIX
EPWM11 00004a00 00000100 00000100 00000000 RWIX
EPWM12 00004b00 00000100 00000100 00000000 RWIX
ECAP1 00005000 00000020 00000020 00000000 RWIX
ECAP2 00005020 00000020 00000020 00000000 RWIX
ECAP3 00005040 00000020 00000020 00000000 RWIX
ECAP4 00005060 00000020 00000020 00000000 RWIX
ECAP5 00005080 00000020 00000020 00000000 RWIX
ECAP6 000050a0 00000020 00000020 00000000 RWIX
EQEP1 00005100 00000040 00000022 0000001e RWIX
EQEP2 00005140 00000040 00000022 0000001e RWIX
EQEP3 00005180 00000040 00000022 0000001e RWIX
DACA 00005c00 00000010 00000008 00000008 RWIX
DACB 00005c10 00000010 00000008 00000008 RWIX
DACC 00005c20 00000010 00000008 00000008 RWIX
CMPSS1 00005c80 00000020 00000020 00000000 RWIX
CMPSS2 00005ca0 00000020 00000020 00000000 RWIX
CMPSS3 00005cc0 00000020 00000020 00000000 RWIX
CMPSS4 00005ce0 00000020 00000020 00000000 RWIX
CMPSS5 00005d00 00000020 00000020 00000000 RWIX
CMPSS6 00005d20 00000020 00000020 00000000 RWIX
CMPSS7 00005d40 00000020 00000020 00000000 RWIX
CMPSS8 00005d60 00000020 00000020 00000000 RWIX
SDFM1 00005e00 00000080 00000080 00000000 RWIX
SDFM2 00005e80 00000080 00000080 00000000 RWIX
MCBSPA 00006000 00000040 00000024 0000001c RWIX
MCBSPB 00006040 00000040 00000024 0000001c RWIX
SPIA 00006100 00000010 00000010 00000000 RWIX
SPIB 00006110 00000010 00000010 00000000 RWIX
*** 00006120 00000010 00000010 00000000 RWIX
SPID 00006130 00000010 00000000 00000010 RWIX
UPP 00006200 00000100 00000000 00000100 RWIX
WD 00007000 00000040 0000002b 00000015 RWIX
NMIINTRUPT 00007060 00000010 00000007 00000009 RWIX
XINT 00007070 00000010 0000000b 00000005 RWIX
SCIA 00007200 00000010 00000010 00000000 RWIX
SCIB 00007210 00000010 00000010 00000000 RWIX
SCIC 00007220 00000010 00000010 00000000 RWIX
SCID 00007230 00000010 00000010 00000000 RWIX
I2CA 00007300 00000040 00000022 0000001e RWIX
I2CB 00007340 00000040 00000022 0000001e RWIX
ADCA 00007400 00000080 00000080 00000000 RWIX
ADCB 00007480 00000080 00000080 00000000 RWIX
ADCC 00007500 00000080 00000080 00000000 RWIX
ADCD 00007580 00000080 00000080 00000000 RWIX
INPUT_XBAR 00007900 00000020 00000000 00000020 RWIX
XBAR 00007920 00000020 00000000 00000020 RWIX
SYNC_SOC 00007940 00000010 00000000 00000010 RWIX
DMACLASRCSEL 00007980 00000040 0000001a 00000026 RWIX
EPWM_XBAR 00007a00 00000040 00000000 00000040 RWIX
CLB_XBAR 00007a40 00000040 00000000 00000040 RWIX
OUTPUT_XBAR 00007a80 00000040 00000000 00000040 RWIX
GPIOCTRL 00007c00 00000180 00000000 00000180 RWIX
GPIODAT 00007f00 00000030 00000030 00000000 RWIX
RAMLS0 00008000 00000800 00000000 00000800 RWIX
RAMLS1 00008800 00000800 00000100 00000700 RWIX
RAMLS2 00009000 00000800 00000246 000005ba RWIX
RAMLS3 00009800 00000800 000001c0 00000640 RWIX
RAMGS5 00011000 00001000 00000000 00001000 RWIX
RAMGS6 00012000 00001000 00000000 00001000 RWIX
RAMGS7 00013000 00001000 00000000 00001000 RWIX
RAMGS8 00014000 00001000 00000000 00001000 RWIX
RAMGS9 00015000 00001000 00000000 00001000 RWIX
RAMGS10 00016000 00001000 00000000 00001000 RWIX
RAMGS11 00017000 00001000 00000000 00001000 RWIX
RAMGS12 00018000 00001000 00000000 00001000 RWIX
RAMGS13 00019000 00001000 00000000 00001000 RWIX
RAMGS14 0001a000 00001000 00000008 00000ff8 RWIX
RAMGS15 0001b000 00001000 0000000a 00000ff6 RWIX
EMIF1 00047000 00000800 00000070 00000790 RWIX
EMIF2 00047800 00000800 00000070 00000790 RWIX
CANA 00048000 00000800 00000000 00000800 RWIX
CANA_MSG_RAM 00049000 00000800 00000000 00000800 RWIX
CANB 0004a000 00000800 00000000 00000800 RWIX
CANB_MSG_RAM 0004b000 00000800 00000000 00000800 RWIX
IPC 00050000 00000024 00000024 00000000 RWIX
FLASHPUMPSEMAPHORE 00050024 00000002 00000002 00000000 RWIX
DEV_CFG 0005d000 00000180 00000000 00000180 RWIX
ANALOG_SUBSYS 0005d180 00000080 00000000 00000080 RWIX
CLK_CFG 0005d200 00000100 00000032 000000ce RWIX
CPU_SYS 0005d300 00000100 00000082 0000007e RWIX
ROMPREFETCH 0005e608 00000002 00000000 00000002 RWIX
DCSM_Z1 0005f000 00000030 00000024 0000000c RWIX
DCSM_Z2 0005f040 00000030 00000024 0000000c RWIX
DCSM_COMMON 0005f070 00000010 00000008 00000008 RWIX
MEMCFG 0005f400 00000080 00000080 00000000 RWIX
EMIF1CONFIG 0005f480 00000020 00000020 00000000 RWIX
EMIF2CONFIG 0005f4a0 00000020 00000000 00000020 RWIX
ACCESSPROTECTION 0005f4c0 00000040 00000040 00000000 RWIX
MEMORYERROR 0005f500 00000040 00000040 00000000 RWIX
ROMWAITSTATE 0005f540 00000002 00000000 00000002 RWIX
FLASH0_CTRL 0005f800 00000300 00000182 0000017e RWIX
FLASH0_ECC 0005fb00 00000040 00000028 00000018 RWIX
DCSM_Z1_OTP 00078000 00000020 00000020 00000000 RWIX
DCSM_Z2_OTP 00078200 00000020 00000020 00000000 RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
.cinit 0 00000122 00000138
00000122 000000aa Main_CPU2.obj (.cinit)
000001cc 00000074 SM_INV_CPU2.obj (.cinit)
00000240 0000000e rts2800_fpu32.lib : exit.c.obj (.cinit)
0000024e 00000005 : _lock.c.obj (.cinit:__lock)
00000253 00000005 : _lock.c.obj (.cinit:__unlock)
00000258 00000002 --HOLE-- [fill = 0]
AdcaResultFile
* 1 00000b00 00000018 UNINITIALIZED
00000b00 00000018 F2837xD_GlobalVariableDefs_CPU2.obj (AdcaResultFile)
AdcbResultFile
* 1 00000b20 00000018 UNINITIALIZED
00000b20 00000018 F2837xD_GlobalVariableDefs_CPU2.obj (AdcbResultFile)
AdccResultFile
* 1 00000b40 00000018 UNINITIALIZED
00000b40 00000018 F2837xD_GlobalVariableDefs_CPU2.obj (AdccResultFile)
AdcdResultFile
* 1 00000b60 00000018 UNINITIALIZED
00000b60 00000018 F2837xD_GlobalVariableDefs_CPU2.obj (AdcdResultFile)
CpuTimer0RegsFile
* 1 00000c00 00000008 UNINITIALIZED
00000c00 00000008 F2837xD_GlobalVariableDefs_CPU2.obj (CpuTimer0RegsFile)
CpuTimer1RegsFile
* 1 00000c08 00000008 UNINITIALIZED
00000c08 00000008 F2837xD_GlobalVariableDefs_CPU2.obj (CpuTimer1RegsFile)
CpuTimer2RegsFile
* 1 00000c10 00000008 UNINITIALIZED
00000c10 00000008 F2837xD_GlobalVariableDefs_CPU2.obj (CpuTimer2RegsFile)
PieCtrlRegsFile
* 1 00000ce0 0000001a UNINITIALIZED
00000ce0 0000001a F2837xD_GlobalVariableDefs_CPU2.obj (PieCtrlRegsFile)
PieVectTableFile
* 1 00000d00 000001c0 UNINITIALIZED
00000d00 000001c0 F2837xD_GlobalVariableDefs_CPU2.obj (PieVectTableFile)
EmuKeyVar
* 1 00000d00 00000001 UNINITIALIZED
00000d00 00000001 F2837xD_GlobalVariableDefs_CPU2.obj (EmuKeyVar)
EmuBModeVar
* 1 00000d01 00000001 UNINITIALIZED
00000d01 00000001 F2837xD_GlobalVariableDefs_CPU2.obj (EmuBModeVar)
FlashCallbackVar
* 1 00000d02 00000000 UNINITIALIZED
FlashScalingVar
DmaRegsFile
* 1 00001000 000000e0 UNINITIALIZED
00001000 000000e0 F2837xD_GlobalVariableDefs_CPU2.obj (DmaRegsFile)
EPwm1RegsFile
* 1 00004000 00000100 UNINITIALIZED
00004000 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm1RegsFile)
EPwm2RegsFile
* 1 00004100 00000100 UNINITIALIZED
00004100 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm2RegsFile)
EPwm3RegsFile
* 1 00004200 00000100 UNINITIALIZED
00004200 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm3RegsFile)
EPwm4RegsFile
* 1 00004300 00000100 UNINITIALIZED
00004300 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm4RegsFile)
EPwm5RegsFile
* 1 00004400 00000100 UNINITIALIZED
00004400 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm5RegsFile)
EPwm6RegsFile
* 1 00004500 00000100 UNINITIALIZED
00004500 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm6RegsFile)
EPwm7RegsFile
* 1 00004600 00000100 UNINITIALIZED
00004600 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm7RegsFile)
EPwm8RegsFile
* 1 00004700 00000100 UNINITIALIZED
00004700 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm8RegsFile)
EPwm9RegsFile
* 1 00004800 00000100 UNINITIALIZED
00004800 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm9RegsFile)
EPwm10RegsFile
* 1 00004900 00000100 UNINITIALIZED
00004900 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm10RegsFile)
EPwm11RegsFile
* 1 00004a00 00000100 UNINITIALIZED
00004a00 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm11RegsFile)
EPwm12RegsFile
* 1 00004b00 00000100 UNINITIALIZED
00004b00 00000100 F2837xD_GlobalVariableDefs_CPU2.obj (EPwm12RegsFile)
ECap1RegsFile
* 1 00005000 00000020 UNINITIALIZED
00005000 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (ECap1RegsFile)
ECap2RegsFile
* 1 00005020 00000020 UNINITIALIZED
00005020 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (ECap2RegsFile)
ECap3RegsFile
* 1 00005040 00000020 UNINITIALIZED
00005040 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (ECap3RegsFile)
ECap4RegsFile
* 1 00005060 00000020 UNINITIALIZED
00005060 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (ECap4RegsFile)
ECap5RegsFile
* 1 00005080 00000020 UNINITIALIZED
00005080 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (ECap5RegsFile)
ECap6RegsFile
* 1 000050a0 00000020 UNINITIALIZED
000050a0 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (ECap6RegsFile)
DacaRegsFile
* 1 00005c00 00000008 UNINITIALIZED
00005c00 00000008 F2837xD_GlobalVariableDefs_CPU2.obj (DacaRegsFile)
DacbRegsFile
* 1 00005c10 00000008 UNINITIALIZED
00005c10 00000008 F2837xD_GlobalVariableDefs_CPU2.obj (DacbRegsFile)
DaccRegsFile
* 1 00005c20 00000008 UNINITIALIZED
00005c20 00000008 F2837xD_GlobalVariableDefs_CPU2.obj (DaccRegsFile)
Sdfm1RegsFile
* 1 00005e00 00000080 UNINITIALIZED
00005e00 00000080 F2837xD_GlobalVariableDefs_CPU2.obj (Sdfm1RegsFile)
Sdfm2RegsFile
* 1 00005e80 00000080 UNINITIALIZED
00005e80 00000080 F2837xD_GlobalVariableDefs_CPU2.obj (Sdfm2RegsFile)
SpiaRegsFile
* 1 00006100 00000010 UNINITIALIZED
00006100 00000010 F2837xD_GlobalVariableDefs_CPU2.obj (SpiaRegsFile)
SpibRegsFile
* 1 00006110 00000010 UNINITIALIZED
00006110 00000010 F2837xD_GlobalVariableDefs_CPU2.obj (SpibRegsFile)
SpicRegsFile
* 1 00006120 00000010 UNINITIALIZED
00006120 00000010 F2837xD_GlobalVariableDefs_CPU2.obj (SpicRegsFile)
AdcaRegsFile
* 1 00007400 00000080 UNINITIALIZED
00007400 00000080 F2837xD_GlobalVariableDefs_CPU2.obj (AdcaRegsFile)
AdcbRegsFile
* 1 00007480 00000080 UNINITIALIZED
00007480 00000080 F2837xD_GlobalVariableDefs_CPU2.obj (AdcbRegsFile)
AdccRegsFile
* 1 00007500 00000080 UNINITIALIZED
00007500 00000080 F2837xD_GlobalVariableDefs_CPU2.obj (AdccRegsFile)
AdcdRegsFile
* 1 00007580 00000080 UNINITIALIZED
00007580 00000080 F2837xD_GlobalVariableDefs_CPU2.obj (AdcdRegsFile)
Cla1RegsFile
* 1 00001400 0000003e UNINITIALIZED
00001400 0000003e F2837xD_GlobalVariableDefs_CPU2.obj (Cla1RegsFile)
Cla1SoftIntRegsFile
* 1 00000ce0 00000004 DSECT
00000ce0 00000004 F2837xD_GlobalVariableDefs_CPU2.obj (Cla1SoftIntRegsFile)
Cmpss1RegsFile
* 1 00005c80 00000020 UNINITIALIZED
00005c80 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss1RegsFile)
Cmpss2RegsFile
* 1 00005ca0 00000020 UNINITIALIZED
00005ca0 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss2RegsFile)
Cmpss3RegsFile
* 1 00005cc0 00000020 UNINITIALIZED
00005cc0 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss3RegsFile)
Cmpss4RegsFile
* 1 00005ce0 00000020 UNINITIALIZED
00005ce0 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss4RegsFile)
Cmpss5RegsFile
* 1 00005d00 00000020 UNINITIALIZED
00005d00 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss5RegsFile)
Cmpss6RegsFile
* 1 00005d20 00000020 UNINITIALIZED
00005d20 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss6RegsFile)
Cmpss7RegsFile
* 1 00005d40 00000020 UNINITIALIZED
00005d40 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss7RegsFile)
Cmpss8RegsFile
* 1 00005d60 00000020 UNINITIALIZED
00005d60 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Cmpss8RegsFile)
DmaClaSrcSelRegsFile
* 1 00007980 0000001a UNINITIALIZED
00007980 0000001a F2837xD_GlobalVariableDefs_CPU2.obj (DmaClaSrcSelRegsFile)
Emif1RegsFile
* 1 00047000 00000070 UNINITIALIZED
00047000 00000070 F2837xD_GlobalVariableDefs_CPU2.obj (Emif1RegsFile)
Emif2RegsFile
* 1 00047800 00000070 UNINITIALIZED
00047800 00000070 F2837xD_GlobalVariableDefs_CPU2.obj (Emif2RegsFile)
DcsmZ1RegsFile
* 1 0005f000 00000024 UNINITIALIZED
0005f000 00000024 F2837xD_GlobalVariableDefs_CPU2.obj (DcsmZ1RegsFile)
DcsmZ2RegsFile
* 1 0005f040 00000024 UNINITIALIZED
0005f040 00000024 F2837xD_GlobalVariableDefs_CPU2.obj (DcsmZ2RegsFile)
DcsmCommonRegsFile
* 1 0005f070 00000008 UNINITIALIZED
0005f070 00000008 F2837xD_GlobalVariableDefs_CPU2.obj (DcsmCommonRegsFile)
DcsmZ1OtpFile
* 1 00078000 00000020 NOLOAD SECTION
00078000 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (DcsmZ1OtpFile)
DcsmZ2OtpFile
* 1 00078200 00000020 NOLOAD SECTION
00078200 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (DcsmZ2OtpFile)
EQep1RegsFile
* 1 00005100 00000022 UNINITIALIZED
00005100 00000022 F2837xD_GlobalVariableDefs_CPU2.obj (EQep1RegsFile)
EQep2RegsFile
* 1 00005140 00000022 UNINITIALIZED
00005140 00000022 F2837xD_GlobalVariableDefs_CPU2.obj (EQep2RegsFile)
EQep3RegsFile
* 1 00005180 00000022 UNINITIALIZED
00005180 00000022 F2837xD_GlobalVariableDefs_CPU2.obj (EQep3RegsFile)
Flash0CtrlRegsFile
* 1 0005f800 00000182 UNINITIALIZED
0005f800 00000182 F2837xD_GlobalVariableDefs_CPU2.obj (Flash0CtrlRegsFile)
Flash0EccRegsFile
* 1 0005fb00 00000028 UNINITIALIZED
0005fb00 00000028 F2837xD_GlobalVariableDefs_CPU2.obj (Flash0EccRegsFile)
GpioDataRegsFile
* 1 00007f00 00000030 UNINITIALIZED
00007f00 00000030 F2837xD_GlobalVariableDefs_CPU2.obj (GpioDataRegsFile)
I2caRegsFile
* 1 00007300 00000022 UNINITIALIZED
00007300 00000022 F2837xD_GlobalVariableDefs_CPU2.obj (I2caRegsFile)
I2cbRegsFile
* 1 00007340 00000022 UNINITIALIZED
00007340 00000022 F2837xD_GlobalVariableDefs_CPU2.obj (I2cbRegsFile)
IpcRegsFile
* 1 00050000 00000024 UNINITIALIZED
00050000 00000024 F2837xD_GlobalVariableDefs_CPU2.obj (IpcRegsFile)
FlashPumpSemaphoreRegsFile
* 1 00050024 00000002 UNINITIALIZED
00050024 00000002 F2837xD_GlobalVariableDefs_CPU2.obj (FlashPumpSemaphoreRegsFile)
MemCfgRegsFile
* 1 0005f400 00000080 UNINITIALIZED
0005f400 00000080 F2837xD_GlobalVariableDefs_CPU2.obj (MemCfgRegsFile)
Emif1ConfigRegsFile
* 1 0005f480 00000020 UNINITIALIZED
0005f480 00000020 F2837xD_GlobalVariableDefs_CPU2.obj (Emif1ConfigRegsFile)
AccessProtectionRegsFile
* 1 0005f4c0 00000040 UNINITIALIZED
0005f4c0 00000040 F2837xD_GlobalVariableDefs_CPU2.obj (AccessProtectionRegsFile)
MemoryErrorRegsFile
* 1 0005f500 00000040 UNINITIALIZED
0005f500 00000040 F2837xD_GlobalVariableDefs_CPU2.obj (MemoryErrorRegsFile)
McbspaRegsFile
* 1 00006000 00000024 UNINITIALIZED
00006000 00000024 F2837xD_GlobalVariableDefs_CPU2.obj (McbspaRegsFile)
McbspbRegsFile
* 1 00006040 00000024 UNINITIALIZED
00006040 00000024 F2837xD_GlobalVariableDefs_CPU2.obj (McbspbRegsFile)
NmiIntruptRegsFile
* 1 00007060 00000007 UNINITIALIZED
00007060 00000007 F2837xD_GlobalVariableDefs_CPU2.obj (NmiIntruptRegsFile)
SciaRegsFile
* 1 00007200 00000010 UNINITIALIZED
00007200 00000010 F2837xD_GlobalVariableDefs_CPU2.obj (SciaRegsFile)
ScibRegsFile
* 1 00007210 00000010 UNINITIALIZED
00007210 00000010 F2837xD_GlobalVariableDefs_CPU2.obj (ScibRegsFile)
ScicRegsFile
* 1 00007220 00000010 UNINITIALIZED
00007220 00000010 F2837xD_GlobalVariableDefs_CPU2.obj (ScicRegsFile)
ScidRegsFile
* 1 00007230 00000010 UNINITIALIZED
00007230 00000010 F2837xD_GlobalVariableDefs_CPU2.obj (ScidRegsFile)
ClkCfgRegsFile
* 1 0005d200 00000032 UNINITIALIZED
0005d200 00000032 F2837xD_GlobalVariableDefs_CPU2.obj (ClkCfgRegsFile)
CpuSysRegsFile
* 1 0005d300 00000082 UNINITIALIZED
0005d300 00000082 F2837xD_GlobalVariableDefs_CPU2.obj (CpuSysRegsFile)
WdRegsFile
* 1 00007000 0000002b UNINITIALIZED
00007000 0000002b F2837xD_GlobalVariableDefs_CPU2.obj (WdRegsFile)
XintRegsFile
* 1 00007070 0000000b UNINITIALIZED
00007070 0000000b F2837xD_GlobalVariableDefs_CPU2.obj (XintRegsFile)
codestart
* 0 00000000 00000002
00000000 00000002 F2837xD_CodeStartBranch_CPU2.obj (codestart)
.TI.ramfunc
* 0 00000272 00000004
00000272 00000004 F2837xD_usDelay_CPU2.obj (.TI.ramfunc)
.pinit 0 00000122 00000000 UNINITIALIZED
.switch 0 0000025a 00000018
0000025a 00000018 SM_DAB_CPU2.obj (.switch:_SM_DAB)
.reset 0 003fffc0 00000002 DSECT
003fffc0 00000002 rts2800_fpu32.lib : boot28.asm.obj (.reset)
.stack 1 00000400 00000100 UNINITIALIZED
00000400 00000100 --HOLE--
.ebss 1 00009000 00000246 UNINITIALIZED
00009000 00000200 Main_CPU2.obj (.ebss)
00009200 00000024 SM_INV_CPU2.obj (.ebss)
00009224 00000018 F2837xD_CpuTimers_CPU2.obj (.ebss)
0000923c 00000002 rts2800_fpu32.lib : _lock.c.obj (.ebss:__lock)
0000923e 00000002 : _lock.c.obj (.ebss:__unlock)
00009240 00000006 : exit.c.obj (.ebss)
.econst 1 00009800 000001c0
00009800 000001c0 F2837xD_PieVect_CPU2.obj (.econst:_PieVectTableInit)
SHARERAMGS14
* 1 0001a000 00000008 UNINITIALIZED
0001a000 00000008 Main_CPU2.obj (SHARERAMGS14)
SHARERAMGS15
* 1 0001b000 0000000a UNINITIALIZED
0001b000 0000000a Main_CPU2.obj (SHARERAMGS15)
CLAscratch
* 1 00008800 00000100 UNINITIALIZED
00008800 00000100 --HOLE--
.text.1 0 0000b000 00000800
0000b000 00000585 F2837xD_DefaultISR_CPU2.obj (.text:retain)
0000b585 00000213 F2837xD_SysCtrl_CPU2.obj (.text)
0000b798 00000056 rts2800_fpu32.lib : boot28.asm.obj (.text)
0000b7ee 0000000f Interrupt_CPU2.obj (.text:retain)
0000b7fd 00000002 rts2800_fpu32.lib : pre_init.c.obj (.text)
0000b7ff 00000001 : startup.c.obj (.text)
.text.2 0 0000b800 000007fe
0000b800 00000282 SM_INV_CPU2.obj (.text)
0000ba82 00000188 SM_DAB_CPU2.obj (.text)
0000bc0a 000000c3 Main_CPU2.obj (.text)
0000bccd 0000007c F2837xD_CpuTimers_CPU2.obj (.text)
0000bd49 00000053 SM_IR_DAB_CPU2.obj (.text)
0000bd9c 00000052 Loop_CPU2.obj (.text:retain)
0000bdee 00000051 SharedRAM_CPU2.obj (.text)
0000be3f 00000041 SharedRAM_CPU2.obj (.text:retain)
0000be80 0000003b SM_IR_INV_CPU2.obj (.text)
0000bebb 0000003a F2837xD_Ipc_Driver_Util_CPU2.obj (.text)
0000bef5 00000035 F2837xD_Gpio_CPU2.obj (.text)
0000bf2a 00000029 rts2800_fpu32.lib : exit.c.obj (.text)
0000bf53 00000028 DAC_CPU2.obj (.text)
0000bf7b 00000028 F2837xD_PieCtrl_CPU2.obj (.text)
0000bfa3 00000026 F2837xD_PieVect_CPU2.obj (.text)
0000bfc9 00000024 rts2800_fpu32.lib : cpy_tbl.c.obj (.text)
0000bfed 00000009 : _lock.c.obj (.text)
0000bff6 00000008 F2837xD_CodeStartBranch_CPU2.obj (.text)
.text.3 0 0000c000 00000064
0000c000 0000001e rts2800_fpu32.lib : memcpy.c.obj (.text)
0000c01e 00000019 : args_main.c.obj (.text)
0000c037 00000018 : ll_aox28.asm.obj (.text)
0000c04f 00000015 System_Config_CPU2.obj (.text)
MODULE SUMMARY
Module code initialized data uninitialized data
F2837xD_GlobalVariableDefs_CPU2.obj 0 0 6983
F2837xD_DefaultISR_CPU2.obj 1413 0 0
Main_CPU2.obj 195 170 530
SM_INV_CPU2.obj 642 116 36
F2837xD_SysCtrl_CPU2.obj 531 0 0
F2837xD_PieVect_CPU2.obj 38 448 0
SM_DAB_CPU2.obj 392 24 0
F2837xD_CpuTimers_CPU2.obj 124 0 24
SharedRAM_CPU2.obj 146 0 0
SM_IR_DAB_CPU2.obj 83 0 0
Loop_CPU2.obj 82 0 0
SM_IR_INV_CPU2.obj 59 0 0
F2837xD_Ipc_Driver_Util_CPU2.obj 58 0 0
F2837xD_Gpio_CPU2.obj 53 0 0
DAC_CPU2.obj 40 0 0
F2837xD_PieCtrl_CPU2.obj 40 0 0
System_Config_CPU2.obj 21 0 0
Interrupt_CPU2.obj 15 0 0
F2837xD_CodeStartBranch_CPU2.obj 10 0 0
F2837xD_usDelay_CPU2.obj 4 0 0
Total: 3946 758 7573
C:/ti/ccsv8/tools/compiler/ti-cgt-c2000_18.1.1.LTS/lib/rts2800_fpu32.lib
boot28.asm.obj 86 0 0
exit.c.obj 41 14 6
cpy_tbl.c.obj 36 0 0
memcpy.c.obj 30 0 0
args_main.c.obj 25 0 0
ll_aox28.asm.obj 24 0 0
_lock.c.obj 9 10 4
pre_init.c.obj 2 0 0
startup.c.obj 1 0 0
Total: 254 24 10
Stack: 0 0 256
Grand Total: 4200 782 7839
GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
address data page name
00000400 10 (00000400) __stack
00000b00 2c (00000b00) _AdcaResultRegs
00000b20 2c (00000b00) _AdcbResultRegs
00000b40 2d (00000b40) _AdccResultRegs
00000b60 2d (00000b40) _AdcdResultRegs
00000c00 30 (00000c00) _CpuTimer0Regs
00000c08 30 (00000c00) _CpuTimer1Regs
00000c10 30 (00000c00) _CpuTimer2Regs
00000ce0 33 (00000cc0) _Cla1SoftIntRegs
00000ce0 33 (00000cc0) _PieCtrlRegs
00000d00 34 (00000d00) _EmuKey
00000d00 34 (00000d00) _PieVectTable
00000d01 34 (00000d00) _EmuBMode
00001000 40 (00001000) _DmaRegs
00001400 50 (00001400) _Cla1Regs
00004000 100 (00004000) _EPwm1Regs
00004100 104 (00004100) _EPwm2Regs
00004200 108 (00004200) _EPwm3Regs
00004300 10c (00004300) _EPwm4Regs
00004400 110 (00004400) _EPwm5Regs
00004500 114 (00004500) _EPwm6Regs
00004600 118 (00004600) _EPwm7Regs
00004700 11c (00004700) _EPwm8Regs
00004800 120 (00004800) _EPwm9Regs
00004900 124 (00004900) _EPwm10Regs
00004a00 128 (00004a00) _EPwm11Regs
00004b00 12c (00004b00) _EPwm12Regs
00005000 140 (00005000) _ECap1Regs
00005020 140 (00005000) _ECap2Regs
00005040 141 (00005040) _ECap3Regs
00005060 141 (00005040) _ECap4Regs
00005080 142 (00005080) _ECap5Regs
000050a0 142 (00005080) _ECap6Regs
00005100 144 (00005100) _EQep1Regs
00005140 145 (00005140) _EQep2Regs
00005180 146 (00005180) _EQep3Regs
00005c00 170 (00005c00) _DacaRegs
00005c10 170 (00005c00) _DacbRegs
00005c20 170 (00005c00) _DaccRegs
00005c80 172 (00005c80) _Cmpss1Regs
00005ca0 172 (00005c80) _Cmpss2Regs
00005cc0 173 (00005cc0) _Cmpss3Regs
00005ce0 173 (00005cc0) _Cmpss4Regs
00005d00 174 (00005d00) _Cmpss5Regs
00005d20 174 (00005d00) _Cmpss6Regs
00005d40 175 (00005d40) _Cmpss7Regs
00005d60 175 (00005d40) _Cmpss8Regs
00005e00 178 (00005e00) _Sdfm1Regs
00005e80 17a (00005e80) _Sdfm2Regs
00006000 180 (00006000) _McbspaRegs
00006040 181 (00006040) _McbspbRegs
00006100 184 (00006100) _SpiaRegs
00006110 184 (00006100) _SpibRegs
00006120 184 (00006100) _SpicRegs
00007000 1c0 (00007000) _WdRegs
00007060 1c1 (00007040) _NmiIntruptRegs
00007070 1c1 (00007040) _XintRegs
00007200 1c8 (00007200) _SciaRegs
00007210 1c8 (00007200) _ScibRegs
00007220 1c8 (00007200) _ScicRegs
00007230 1c8 (00007200) _ScidRegs
00007300 1cc (00007300) _I2caRegs
00007340 1cd (00007340) _I2cbRegs
00007400 1d0 (00007400) _AdcaRegs
00007480 1d2 (00007480) _AdcbRegs
00007500 1d4 (00007500) _AdccRegs
00007580 1d6 (00007580) _AdcdRegs
00007980 1e6 (00007980) _DmaClaSrcSelRegs
00007f00 1fc (00007f00) _GpioDataRegs
00009000 240 (00009000) _sm_exit_soft_start_dab
00009001 240 (00009000) _sm_exit_soft_start_inv
00009002 240 (00009000) _sm_pwm_state_inv
00009003 240 (00009000) _sm_inrush_sw_timer
00009004 240 (00009000) _sm_dab_xcode_CPU2
00009005 240 (00009000) _sm_inv_xcode_CPU2
00009006 240 (00009000) _sm_inrush_batt_state
00009007 240 (00009000) _sm_inrush_inv_state
00009008 240 (00009000) _sm_pwm_state_dab
00009009 240 (00009000) _sm_memo_type
0000900a 240 (00009000) _sm_com_type_prev
0000900b 240 (00009000) _sm_memo_new_state
0000900c 240 (00009000) _sm_memo_old_state
0000900d 240 (00009000) _sm_idx_changed_state
0000900e 240 (00009000) _sm_num_changed_state
0000900f 240 (00009000) _sm_com_type
00009010 240 (00009000) _sm_idx_snd_changed_state
00009011 240 (00009000) _sm_memo_code
00009012 240 (00009000) _sm_inv_enable
00009013 240 (00009000) _sm_inv_pcode_CPU2
00009014 240 (00009000) _sm_dab_oldstate_CPU2
00009015 240 (00009000) _sm_dab_state_CPU2
00009016 240 (00009000) _sm_inv_oldstate_CPU2
00009017 240 (00009000) _sm_inv_state_CPU2
00009018 240 (00009000) _sm_inv_code_CPU2
00009019 240 (00009000) _sm_inv_cnt_block
0000901a 240 (00009000) _sm_dab_enable
0000901b 240 (00009000) _sm_dab_pcode_CPU2
0000901c 240 (00009000) _sm_dab_cnt_block
0000901d 240 (00009000) _sm_dab_code_CPU2
0000901e 240 (00009000) _ptr_system_timers
00009020 240 (00009000) _ptr_cpu1_record
00009022 240 (00009000) _system_flags
00009024 240 (00009000) _ptr_system_flags
00009026 240 (00009000) _fw_version_CPU1
00009028 240 (00009000) _fw_version_CPU2
0000902a 240 (00009000) _sm_inrush_batt_timer
0000902c 240 (00009000) _ptr_cpu2_record
0000902e 240 (00009000) _sm_inv_timer
00009030 240 (00009000) _sm_inrush_inv_timer
00009032 240 (00009000) _sm_dab_timer
00009034 240 (00009000) _sm_absolute_time
00009036 240 (00009000) _cpu1_gsram_record
00009040 241 (00009040) _DAC_PTR
00009048 241 (00009040) _cpu2_gsram_record
00009052 241 (00009040) _system_timers
00009080 242 (00009080) _sm_changed_state
00009200 248 (00009200) _cnt_check_voutmax_inv
00009201 248 (00009200) _cnt_check_voutmin_inv
00009202 248 (00009200) _cnt_f_temp1_max
00009203 248 (00009200) _button_off
00009204 248 (00009200) _cnt_f_temp1_min
00009205 248 (00009200) _cnt_off_ibat
00009206 248 (00009200) _cnt_negative_ibat
00009207 248 (00009200) _cnt_battery_discharging
00009208 248 (00009200) _cnt_battery_switch_off
00009209 248 (00009200) _cnt_check_inrush
0000920a 248 (00009200) _cnt_button_down_3s
0000920b 248 (00009200) _cnt_warning_temp3
0000920c 248 (00009200) _led_fault_dab
0000920d 248 (00009200) _led_fault_inv
0000920e 248 (00009200) _i
0000920f 248 (00009200) _cnt_f_temp2_min
00009210 248 (00009200) _cnt_f_temp2_max
00009211 248 (00009200) _fan2_error
00009212 248 (00009200) _fan1_error
00009213 248 (00009200) _cnt_warning_temp1
00009214 248 (00009200) _cnt_dec_block_inv
00009216 248 (00009200) _cnt_float_charge
00009218 248 (00009200) _cnt_dec_block_dab
0000921a 248 (00009200) _cnt_full_charge
0000921c 248 (00009200) _cnt_max_pout_react
0000921e 248 (00009200) _cnt_max_pout_1s
00009220 248 (00009200) _cnt_max_pout_60s
00009222 248 (00009200) _cnt_max_pout_10s
00009224 248 (00009200) _CpuTimer1
0000922c 248 (00009200) _CpuTimer2
00009234 248 (00009200) _CpuTimer0
0000923c 248 (00009200) __lock
0000923e 248 (00009200) __unlock
00009240 249 (00009240) ___TI_enable_exit_profile_output
00009242 249 (00009240) ___TI_cleanup_ptr
00009244 249 (00009240) ___TI_dtors_ptr
00009800 260 (00009800) _PieVectTableInit
0001a000 680 (0001a000) _cpu2_r_array
0001b000 6c0 (0001b000) _cpu2_rw_array
00047000 11c0 (00047000) _Emif1Regs
00047800 11e0 (00047800) _Emif2Regs
00050000 1400 (00050000) _IpcRegs
00050024 1400 (00050000) _FlashPumpSemaphoreRegs
0005d200 1748 (0005d200) _ClkCfgRegs
0005d300 174c (0005d300) _CpuSysRegs
0005f000 17c0 (0005f000) _DcsmZ1Regs
0005f040 17c1 (0005f040) _DcsmZ2Regs
0005f070 17c1 (0005f040) _DcsmCommonRegs
0005f400 17d0 (0005f400) _MemCfgRegs
0005f480 17d2 (0005f480) _Emif1ConfigRegs
0005f4c0 17d3 (0005f4c0) _AccessProtectionRegs
0005f500 17d4 (0005f500) _MemoryErrorRegs
0005f800 17e0 (0005f800) _Flash0CtrlRegs
0005fb00 17ec (0005fb00) _Flash0EccRegs
00078000 1e00 (00078000) _DcsmZ1Otp
00078200 1e08 (00078200) _DcsmZ2Otp
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
page address name
abs ffffffff .text
0 0000bf2a C$$EXIT
abs 00000100 CLA_SCRATCHPAD_SIZE
0 0000c037 LL$$AND
0 0000c03f LL$$OR
0 0000c047 LL$$XOR
0 0000b0be _ADCA1_ISR
0 0000b33e _ADCA2_ISR
0 0000b348 _ADCA3_ISR
0 0000b352 _ADCA4_ISR
0 0000b334 _ADCA_EVT_ISR
0 0000b0c8 _ADCB1_ISR
0 0000b366 _ADCB2_ISR
0 0000b370 _ADCB3_ISR
0 0000b37a _ADCB4_ISR
0 0000b35c _ADCB_EVT_ISR
0 0000b0d2 _ADCC1_ISR
0 0000b4ce _ADCC2_ISR
0 0000b4d8 _ADCC3_ISR
0 0000b4e2 _ADCC4_ISR
0 0000b4c4 _ADCC_EVT_ISR
0 0000b0f0 _ADCD1_ISR
0 0000b4f6 _ADCD2_ISR
0 0000b500 _ADCD3_ISR
0 0000b50a _ADCD4_ISR
0 0000b4ec _ADCD_EVT_ISR
0 0000b546 _AUX_PLL_SLIP_ISR
1 0005f4c0 _AccessProtectionRegs
1 00007400 _AdcaRegs
1 00000b00 _AdcaResultRegs
1 00007480 _AdcbRegs
1 00000b20 _AdcbResultRegs
1 00007500 _AdccRegs
1 00000b40 _AdccResultRegs
1 00007580 _AdcdRegs
1 00000b60 _AdcdResultRegs
0 0000b774 _AuxAuxClkSel
0 0000b75e _AuxIntOsc2Sel
0 0000b768 _AuxXtalOscSel
0 0000b30c _CANA0_ISR
0 0000b316 _CANA1_ISR
0 0000b320 _CANB0_ISR
0 0000b32a _CANB1_ISR
0 0000b384 _CLA1_1_ISR
0 0000b38e _CLA1_2_ISR
0 0000b398 _CLA1_3_ISR
0 0000b3a2 _CLA1_4_ISR
0 0000b3ac _CLA1_5_ISR
0 0000b3b6 _CLA1_6_ISR
0 0000b3c0 _CLA1_7_ISR
0 0000b3ca _CLA1_8_ISR
0 0000b550 _CLA_OVERFLOW_ISR
0 0000b55a _CLA_UNDERFLOW_ISR
1 00001400 _Cla1Regs
0 00000ce0 _Cla1SoftIntRegs
1 0005d200 _ClkCfgRegs
1 00005c80 _Cmpss1Regs
1 00005ca0 _Cmpss2Regs
1 00005cc0 _Cmpss3Regs
1 00005ce0 _Cmpss4Regs
1 00005d00 _Cmpss5Regs
1 00005d20 _Cmpss6Regs
1 00005d40 _Cmpss7Regs
1 00005d60 _Cmpss8Regs
0 0000bd0e _ConfigCpuTimer
1 0005d300 _CpuSysRegs
1 00009234 _CpuTimer0
1 00000c00 _CpuTimer0Regs
1 00009224 _CpuTimer1
1 00000c08 _CpuTimer1Regs
1 0000922c _CpuTimer2
1 00000c10 _CpuTimer2Regs
0 0000b71d _CsmUnlock
0 0000bf53 _DAC_Init
1 00009040 _DAC_PTR
0 0000b014 _DATALOG_ISR
0 0000b258 _DMA_CH1_ISR
0 0000b262 _DMA_CH2_ISR
0 0000b26c _DMA_CH3_ISR
0 0000b276 _DMA_CH4_ISR
0 0000b280 _DMA_CH5_ISR
0 0000b28a _DMA_CH6_ISR
1 00005c00 _DacaRegs
1 00005c10 _DacbRegs
1 00005c20 _DaccRegs
1 0005f070 _DcsmCommonRegs
1 00078000 _DcsmZ1Otp
1 0005f000 _DcsmZ1Regs
1 00078200 _DcsmZ2Otp
1 0005f040 _DcsmZ2Regs
0 0000b647 _DisableDog
0 0000b608 _DisablePeripheralClocks
1 00007980 _DmaClaSrcSelRegs
1 00001000 _DmaRegs
0 0000b1ae _ECAP1_ISR
0 0000b1b8 _ECAP2_ISR
0 0000b1c2 _ECAP3_ISR
0 0000b1cc _ECAP4_ISR
0 0000b1d6 _ECAP5_ISR
0 0000b1e0 _ECAP6_ISR
1 00005000 _ECap1Regs
1 00005020 _ECap2Regs
1 00005040 _ECap3Regs
1 00005060 _ECap4Regs
1 00005080 _ECap5Regs
1 000050a0 _ECap6Regs
0 0000b514 _EMIF_ERROR_ISR
0 0000b56e _EMPTY_ISR
0 0000b028 _EMU_ISR
0 0000b46a _EPWM10_ISR
0 0000b442 _EPWM10_TZ_ISR
0 0000b474 _EPWM11_ISR
0 0000b44c _EPWM11_TZ_ISR
0 0000b47e _EPWM12_ISR
0 0000b456 _EPWM12_TZ_ISR
0 0000b15e _EPWM1_ISR
0 0000b10e _EPWM1_TZ_ISR
0 0000b168 _EPWM2_ISR
0 0000b118 _EPWM2_TZ_ISR
0 0000b172 _EPWM3_ISR
0 0000b122 _EPWM3_TZ_ISR
0 0000b17c _EPWM4_ISR
0 0000b12c _EPWM4_TZ_ISR
0 0000b186 _EPWM5_ISR
0 0000b136 _EPWM5_TZ_ISR
0 0000b190 _EPWM6_ISR
0 0000b140 _EPWM6_TZ_ISR
0 0000b19a _EPWM7_ISR
0 0000b14a _EPWM7_TZ_ISR
0 0000b1a4 _EPWM8_ISR
0 0000b154 _EPWM8_TZ_ISR
0 0000b460 _EPWM9_ISR
0 0000b438 _EPWM9_TZ_ISR
1 00004900 _EPwm10Regs
1 00004a00 _EPwm11Regs
1 00004b00 _EPwm12Regs
1 00004000 _EPwm1Regs
1 00004100 _EPwm2Regs
1 00004200 _EPwm3Regs
1 00004300 _EPwm4Regs
1 00004400 _EPwm5Regs
1 00004500 _EPwm6Regs
1 00004600 _EPwm7Regs
1 00004700 _EPwm8Regs
1 00004800 _EPwm9Regs
0 0000b1ea _EQEP1_ISR
0 0000b1f4 _EQEP2_ISR
0 0000b1fe _EQEP3_ISR
1 00005100 _EQep1Regs
1 00005140 _EQep2Regs
1 00005180 _EQep3Regs
1 0005f480 _Emif1ConfigRegs
1 00047000 _Emif1Regs
1 00047800 _Emif2Regs
1 00000d01 _EmuBMode
1 00000d00 _EmuKey
0 0000bf9a _EnableInterrupts
0 00000272 _F28x_usDelay
0 0000b528 _FLASH_CORRECTABLE_ERROR_ISR
0 0000b3fc _FPU_OVERFLOW_ISR
0 0000b406 _FPU_UNDERFLOW_ISR
1 0005f800 _Flash0CtrlRegs
1 0005fb00 _Flash0EccRegs
1 00050024 _FlashPumpSemaphoreRegs
0 0000bef5 _GPIO_ReadPin
0 0000bf0c _GPIO_WritePin
1 00007f00 _GpioDataRegs
0 0000b792 _HALT
0 0000b795 _HIB
0 0000b29e _I2CA_FIFO_ISR
0 0000b294 _I2CA_ISR
0 0000b2b2 _I2CB_FIFO_ISR
0 0000b2a8 _I2CB_ISR
1 00007300 _I2caRegs
1 00007340 _I2cbRegs
0 0000b77e _IDLE
0 0000b03c _ILLEGAL_ISR
0 0000b410 _IPC0_ISR
0 0000b41a _IPC1_ISR
0 0000b424 _IPC2_ISR
0 0000b42e _IPC3_ISR
0 0000bef1 _IPCGetBootStatus
0 0000bed2 _IPCLtoRFlagBusy
0 0000bee9 _IPCLtoRFlagClear
0 0000bee1 _IPCLtoRFlagSet
0 0000bebb _IPCRtoLFlagAcknowledge
0 0000bec3 _IPCRtoLFlagBusy
0 0000be3f _IPC_GSRAM_isr
0 0000b655 _InitAuxPll
0 0000bccd _InitCpuTimers
0 0000b58a _InitPeripheralClocks
0 0000bf7b _InitPieCtrl
0 0000bfa3 _InitPieVectTable
0 0000b585 _InitSysCtrl
0 0000bc7b _Init_Vars
0 0000b7ee _IntDefaultHandler
1 00050000 _IpcRegs
0 0000bd9c _Loop_timer0_isr_CPU2
0 0000b230 _MCBSPA_RX_ISR
0 0000b23a _MCBSPA_TX_ISR
0 0000b244 _MCBSPB_RX_ISR
0 0000b24e _MCBSPB_TX_ISR
1 00006000 _McbspaRegs
1 00006040 _McbspbRegs
1 0005f400 _MemCfgRegs
1 0005f500 _MemoryErrorRegs
0 0000b032 _NMI_ISR
0 0000b57b _NOTUSED_ISR
1 00007060 _NmiIntruptRegs
0 0000b564 _PIE_RESERVED_ISR
1 00000ce0 _PieCtrlRegs
1 00000d00 _PieVectTable
1 00009800 _PieVectTableInit
0 0000b532 _RAM_ACCESS_VIOLATION_ISR
0 0000b51e _RAM_CORRECTABLE_ERROR_ISR
0 0000b01e _RTOS_ISR
0 0000b62f _ReleaseFlashPump
0 0000bc4b _Reset_EE_Struct
0 0000b2e4 _SCIA_RX_ISR
0 0000b2ee _SCIA_TX_ISR
0 0000b2f8 _SCIB_RX_ISR
0 0000b302 _SCIB_TX_ISR
0 0000b2bc _SCIC_RX_ISR
0 0000b2c6 _SCIC_TX_ISR
0 0000b2d0 _SCID_RX_ISR
0 0000b2da _SCID_TX_ISR
0 0000b488 _SD1_ISR
0 0000b492 _SD2_ISR
0 0000ba82 _SM_DAB
0 0000b800 _SM_INV
0 0000bd49 _SM_IR_DAB
0 0000be80 _SM_IR_INV
0 0000b208 _SPIA_RX_ISR
0 0000b212 _SPIA_TX_ISR
0 0000b21c _SPIB_RX_ISR
0 0000b226 _SPIB_TX_ISR
0 0000b49c _SPIC_RX_ISR
0 0000b4a6 _SPIC_TX_ISR
0 0000b787 _STANDBY
0 0000b53c _SYS_PLL_SLIP_ISR
1 00007200 _SciaRegs
1 00007210 _ScibRegs
1 00007220 _ScicRegs
1 00007230 _ScidRegs
1 00005e00 _Sdfm1Regs
1 00005e80 _Sdfm2Regs
0 0000b620 _SeizeFlashPump
0 0000b639 _ServiceDog
0 0000c055 _Setup_Timer0
0 0000be25 _Shared_Ram_dataRead
0 0000bdee _Shared_Ram_dataWrite
1 00006100 _SpiaRegs
1 00006110 _SpibRegs
1 00006120 _SpicRegs
0 0000b73e _SysIntOsc1Sel
0 0000b748 _SysIntOsc2Sel
0 0000b752 _SysXtalOscSel
0 0000c04f _System_Config
0 0000b0fa _TIMER0_ISR
0 0000b000 _TIMER1_ISR
0 0000b00a _TIMER2_ISR
0 0000b4b0 _UPPA_ISR
0 0000b4ba _USBA_ISR
0 0000b0a0 _USER10_ISR
0 0000b0aa _USER11_ISR
0 0000b0b4 _USER12_ISR
0 0000b046 _USER1_ISR
0 0000b050 _USER2_ISR
0 0000b05a _USER3_ISR
0 0000b064 _USER4_ISR
0 0000b06e _USER5_ISR
0 0000b078 _USER6_ISR
0 0000b082 _USER7_ISR
0 0000b08c _USER8_ISR
0 0000b096 _USER9_ISR
0 0000b3f2 _VCU_ISR
0 0000b104 _WAKE_ISR
1 00007000 _WdRegs
0 0000beba _Wr_Memo_Log
0 0000b0dc _XINT1_ISR
0 0000b0e6 _XINT2_ISR
0 0000b3d4 _XINT3_ISR
0 0000b3de _XINT4_ISR
0 0000b3e8 _XINT5_ISR
1 00007070 _XintRegs
1 00000500 __STACK_END
abs 00000100 __STACK_SIZE
1 00009242 ___TI_cleanup_ptr
1 00009244 ___TI_dtors_ptr
1 00009240 ___TI_enable_exit_profile_output
abs ffffffff ___TI_pprof_out_hndl
abs ffffffff ___TI_prof_data_size
abs ffffffff ___TI_prof_data_start
abs ffffffff ___binit__
abs ffffffff ___c_args__
0 00000122 ___cinit__
abs ffffffff ___etext__
abs ffffffff ___pinit__
abs ffffffff ___text__
0 0000c01e __args_main
1 0000923c __lock
0 0000bff5 __nop
0 0000bff1 __register_lock
0 0000bfed __register_unlock
1 00000400 __stack
0 0000b7ff __system_post_cinit
0 0000b7fd __system_pre_init
1 0000923e __unlock
0 0000bf2a _abort
1 00009203 _button_off
0 0000b798 _c_int00
1 00009207 _cnt_battery_discharging
1 00009208 _cnt_battery_switch_off
1 0000920a _cnt_button_down_3s
1 00009209 _cnt_check_inrush
1 00009200 _cnt_check_voutmax_inv
1 00009201 _cnt_check_voutmin_inv
1 00009218 _cnt_dec_block_dab
1 00009214 _cnt_dec_block_inv
1 00009202 _cnt_f_temp1_max
1 00009204 _cnt_f_temp1_min
1 00009210 _cnt_f_temp2_max
1 0000920f _cnt_f_temp2_min
1 00009216 _cnt_float_charge
1 0000921a _cnt_full_charge
1 00009222 _cnt_max_pout_10s
1 0000921e _cnt_max_pout_1s
1 00009220 _cnt_max_pout_60s
1 0000921c _cnt_max_pout_react
1 00009206 _cnt_negative_ibat
1 00009205 _cnt_off_ibat
1 00009213 _cnt_warning_temp1
1 0000920b _cnt_warning_temp3
0 0000bfc9 _copy_in
1 00009036 _cpu1_gsram_record
1 00009048 _cpu2_gsram_record
1 0001a000 _cpu2_r_array
1 0001b000 _cpu2_rw_array
0 0000bf2c _exit
1 00009212 _fan1_error
1 00009211 _fan2_error
1 00009026 _fw_version_CPU1
1 00009028 _fw_version_CPU2
1 0000920e _i
1 0000920c _led_fault_dab
1 0000920d _led_fault_inv
0 0000bc0a _main
0 0000c000 _memcpy
1 00009020 _ptr_cpu1_record
1 0000902c _ptr_cpu2_record
1 00009024 _ptr_system_flags
1 0000901e _ptr_system_timers
1 00009034 _sm_absolute_time
1 00009080 _sm_changed_state
1 0000900f _sm_com_type
1 0000900a _sm_com_type_prev
1 0000901c _sm_dab_cnt_block
1 0000901d _sm_dab_code_CPU2
1 0000901a _sm_dab_enable
1 00009014 _sm_dab_oldstate_CPU2
1 0000901b _sm_dab_pcode_CPU2
1 00009015 _sm_dab_state_CPU2
1 00009032 _sm_dab_timer
1 00009004 _sm_dab_xcode_CPU2
1 00009000 _sm_exit_soft_start_dab
1 00009001 _sm_exit_soft_start_inv
1 0000900d _sm_idx_changed_state
1 00009010 _sm_idx_snd_changed_state
1 00009006 _sm_inrush_batt_state
1 0000902a _sm_inrush_batt_timer
1 00009007 _sm_inrush_inv_state
1 00009030 _sm_inrush_inv_timer
1 00009003 _sm_inrush_sw_timer
1 00009019 _sm_inv_cnt_block
1 00009018 _sm_inv_code_CPU2
1 00009012 _sm_inv_enable
1 00009016 _sm_inv_oldstate_CPU2
1 00009013 _sm_inv_pcode_CPU2
1 00009017 _sm_inv_state_CPU2
1 0000902e _sm_inv_timer
1 00009005 _sm_inv_xcode_CPU2
1 00009011 _sm_memo_code
1 0000900b _sm_memo_new_state
1 0000900c _sm_memo_old_state
1 00009009 _sm_memo_type
1 0000900e _sm_num_changed_state
1 00009008 _sm_pwm_state_dab
1 00009002 _sm_pwm_state_inv
1 00009022 _system_flags
1 00009052 _system_timers
abs ffffffff binit
0 00000122 cinit
0 00000000 code_start
abs ffffffff etext
abs ffffffff pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
page address name
0 00000122 cinit
0 0000b028 _EMU_ISR
0 0000b032 _NMI_ISR
0 0000b3f2 _VCU_ISR
0 0000b488 _SD1_ISR
0 0000b492 _SD2_ISR
0 0000b77e _IDLE
0 0000b787 _STANDBY
0 0000b792 _HALT
0 0000b795 _HIB
0 0000b798 _c_int00
0 0000b800 _SM_INV
0 0000ba82 _SM_DAB
0 0000bc0a _main
0 0000bf2a C$$EXIT
0 0000bf2a _abort
0 0000bf2c _exit
0 0000bfc9 _copy_in
0 0000bff5 __nop
0 0000c000 _memcpy
0 0000c037 LL$$AND
0 0000c03f LL$$OR
0 0000c047 LL$$XOR
1 00000400 __stack
1 00000d00 _EmuKey
1 00001000 _DmaRegs
1 00007000 _WdRegs
1 00009040 _DAC_PTR
1 0000920e _i
1 0000923c __lock
1 0000923e __unlock
1 00050000 _IpcRegs
abs ffffffff .text
abs ffffffff binit
abs ffffffff etext
abs ffffffff pinit
[395 symbols]
