Hello Champs,
In F280049, if setting "CAN_setupMessageObject()" flag value as "CAN_MSG_OBJ_RX_INT_ENABLE|CAN_MSG_OBJ_USE_EXT_FILTER", when using "CAN_readMessage()" to read two continuous frames, only the second frame can be read.
If adding CAN_MSG_OBJ_FIFO into flag value, only the first frame can be read.
Would you please kindly suggest how to configure to successfully read both two frames? Thanks!
Linda
