Other Parts Discussed in Thread: TPS62420
One gpio of the dsp is believed damaged: using a multimeter, the R between the gpio and GND is only 0.6 ohm.
Current through VDDIO is pretty big, and measured the R between VDDIO and GND is as small as 8 ohm.
I am thinking if there is other choice, such as disable or isolate the damaged gpio by disconnecting the VDDIO pin or pins nearby the damaged gpio, rather then replacing the f28379D.
Any suggestion will be appreciated. Thanks
