TMS320F28062: AFCI
Part Number: TMS320F28062
 The current product is using the Ti F28062 solution for AFCI at the time. When testing recently, it was found that the harmonic frequency band of the arc fault sampling is very different from the previous test and cannot be effectively identified.
     In response to this question, I would like to consult with you
         1. What was the signal band that you tested for DC arcing in C2000 EVK for AFCI before?
         2. What algorithm is used in your software to identify the arc. And our software engineer left, I can not find the source code of C2000 he left. Can you help to give one for refer.
