Part Number: TMDSSOLARUINVKIT
When I use "SolarMicroInvGUI", the "appProgram.out" will be downloaded into F28035 that the TMDSSOLARUINVKIT will be connected and monitored by the GUI on PC. If I use CCS Eclipse Project "SolarMicroInv_F2803x" to build "SolarMicroInv_F2803x.out", can it be used with "SolarMicroInvGUI", i.e. replace "appProgram.out" to "SolarMicroInv_F2803x.out" in the folder "SolarMicroInvGUI". My purpose is that I would like to change parameters and rebuild the code, then test it with GUI on PC. Thanks.
