F28335: Measure CPU clocks
I'm running software on F28335.
How can I measure how many CPU clocks are required for a specififed operation ?
What is the value of a "tick" in sec ?
  • I think the easiest way is using:
    TIMER0TIM, TIMER0TIMH, TIMER0PRD, TIMER0PRDH,TIMER0TCR
    Am I right ?
    Thanks.
  • Yes -
    You can use the 3 CPU timers on the device to count SYSCLK cycles (can set the prescalers to divide by 1 mode so that each count = 1 SYSCLk cycle). Keep in mind that the TIMERxTIM counter registers count down from the TIMERxPRD register value.
    See the 2833x/2823x System Control and Interrupts Reference Guide section on CPU timers to understand the operation.
