TMS320F28379D: Read Sigma-delta signals from CLA
Part Number: TMS320F28379D
I'm trying to read one sigma-delta signal (at first) from CLA. Then, I want to pass it to CPU to use the data later. I already did this on CPU, but I can't understand what is wrong in my code when i try to do it on CLA, because the interrupt of SDFM1 module, that is conect to TASK1 of CLA, it isn't happening. In others words, the global variable loopCounter1 isn't adding. Could someone help me, please? The codes are below. Thanks everyone.
// FILE:   sdfm_filters_sync_cla_cpu01.c
// TITLE:  SDFM Filter sync CLA Example for F2837xD.
//! \addtogroup cpu01_example_list
//! <h1> SDFM Filter Sync CLA</h1>
//! In this example, SDFM filter data is read by CLA in Cla1Task1. The
//! SDFM configuration is shown below:
//!  - SDFM1 used in this example
//!  - MODE0 Input control mode selected
//!  - Comparator settings
//!       -    Sinc3 filter selected
//!       -    OSR = 32
//!       -    HLT = 0x7FFF (Higher threshold setting)
//!       -    LLT  = 0x0000(Lower threshold setting)
//!  -  Data filter settings
//!      - All the 4 filter modules enabled
//!      - OSR = 256
//!      - All the 4 filters are synchronized by using MFE
//!       (Master Filter enable bit)
//!      - Filter output represented in 16 bit format
//!      - In order to convert 25 bit Data filter
//!        into 16 bit format user needs to right shift by 9 bits for
//!        Sinc3 filter with OSR = 256
//!  - Interrupt module settings for SDFM filter
//!       -    All the 4 higher threshold comparator interrupts disabled
//!       -    All the 4 lower threshold comparator interrupts disabled
//!       -    All the 4 modulator failure interrupts disabled
//!       -    All the 4 filter will generate interrupt when a new filter data
//!         is available
//! \b External \b Connections \n
//!   - SDFM_PIN_MUX_OPTION1 Connect Sigma-Delta streams to
//!     (SD-D1, SD-C1 to SD-D8,SD-C8) on GPIO16-GPIO31
//!   - SDFM_PIN_MUX_OPTION2 Connect Sigma-Delta streams to
//!     (SD-D1, SD-C1 to SD-D8,SD-C8) on GPIO48-GPIO63
//!   - SDFM_PIN_MUX_OPTION3 Connect Sigma-Delta streams to
//!     (SD-D1, SD-C1 to SD-D8,SD-C8) on GPIO122-GPIO137
// $TI Release: F2837xD Support Library v210 $
// $Release Date: Tue Nov  1 14:46:15 CDT 2016 $
// $Copyright: Copyright (C) 2013-2016 Texas Instruments Incorporated -
//             http://www.ti.com/ ALL RIGHTS RESERVED $
// Included Files
#include "F28x_Project.h"
#include "cla_sdfm_filter_sync_shared.h"
#include "F2837xS_sdfm_drivers.h"
#include "F2837xS_struct.h"
// Defines
#define MAX_SAMPLES               1024
#define SDFM_PIN_MUX_OPTION1      1
#define SDFM_PIN_MUX_OPTION2      2
#define SDFM_PIN_MUX_OPTION3      3
#define WAITSTEP                  asm(" RPT #255 || NOP")
// Vari�veis de transi��o entre CL1 e CPU
#ifdef __cplusplus
#pragma DATA_SECTION(Filter1_Result,"Cla1ToCpuMsgRAM");
short Filter1_Result;
#endif
Uint16 gPeripheralNumber;
short  vector[1024];
// Function Prototypes
void Sdfm_configurePins(Uint16);
void Cla_initMemoryMap(void);
void CLA_initCpu1Cla(void);
// Main
int main(void)
   Uint16  pinMuxoption;
   Uint16  HLT, LLT;
// Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the F2837xD_SysCtrl.c file.
    InitSysCtrl();
// Clear all __interrupts and initialize PIE vector table:
// Disable CPU __interrupts
    DINT;
// Initialize PIE control registers to their default state.
// The default state is all PIE __interrupts disabled and flags
// are cleared.
// This function is found in the F2837xD_PieCtrl.c file.
    InitPieCtrl();
// Disable CPU __interrupts and clear all CPU __interrupt flags:
    IER = 0x0000;
    IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the __interrupt
// is not used in this example.  This is useful for debug purposes.
// The shell ISR routines are found in F2837xD_SysCtrl.c.
// This function is found in F2837xD_SysCtrl.c.
    InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
    EALLOW;
//   PieVectTable.SD1_INT = &Sdfm1_ISR;
//   PieVectTable.SD2_INT = &Sdfm2_ISR;
    EDIS;
    EALLOW;
// Enable CPU INT5 which is connected to SDFM INT
    IER |= M_INT11;
// Enable SDFM INTn in the PIE: Group 5 __interrupt 9-10
    PieCtrlRegs.PIEIER5.bit.INTx9 = 1;    // SDFM1 interrupt enabled
    EINT;
    pinMuxoption = SDFM_PIN_MUX_OPTION3;
// Configure GPIO pins as SDFM pins
    Sdfm_configurePins(pinMuxoption);
    EALLOW;
    CPU1_CLA1(ENABLE);            //Enable CPU1.CLA module
    VBUS32_1(CONNECT_TO_CLA1);    //Connect VBUS32_1 (SDFM bus) to CPU1
    EDIS;
// Configure the CLA memory spaces
    Cla_initMemoryMap();
// Configure the CLA task vectors for CPU1
    CLA_initCpu1Cla();
    Cla1ForceTask8andWait();
    WAITSTEP;
    EALLOW;
// Trigger Source for TASK1 of CLA1 = SDFM1
    DmaClaSrcSelRegs.CLA1TASKSRCSEL1.bit.TASK1=CLA_TRIG_SD1INT; // the interrupt now occurs on CLA at the routine TASK1 ; not Sdfm1_ISR, from CPU, anymore
// Lock CLA1TASKSRCSEL1 register
    DmaClaSrcSelRegs.CLA1TASKSRCSELLOCK.bit.CLA1TASKSRCSEL1=1;
    EDIS;
// Select SDFM1
    gPeripheralNumber = SDFM1;
// Input Control Module
// Configure Input Control Mode: Modulator Clock rate = Modulator data rate
    Sdfm_configureInputCtrl(gPeripheralNumber, FILTER1, MODE_0);
    Sdfm_configureInputCtrl(gPeripheralNumber, FILTER2, MODE_0);
    Sdfm_configureInputCtrl(gPeripheralNumber, FILTER3, MODE_0);
    Sdfm_configureInputCtrl(gPeripheralNumber, FILTER4, MODE_0);
// Comparator Module
    HLT = 0x7FFF;    //Over value threshold settings
    LLT = 0x0000;    //Under value threshold settings
// Configure Comparator module's comparator filter type and comparator's OSR
// value, higher threshold, lower threshold
    Sdfm_configureComparator(gPeripheralNumber, FILTER1, SINC3, OSR_32,
                             HLT, LLT);
    Sdfm_configureComparator(gPeripheralNumber, FILTER2, SINC3, OSR_32,
                             HLT, LLT);
    Sdfm_configureComparator(gPeripheralNumber, FILTER3, SINC3, OSR_32,
                             HLT, LLT);
    Sdfm_configureComparator(gPeripheralNumber, FILTER4, SINC3, OSR_32,
                             HLT, LLT);
// Data filter Module
// Configure Data filter modules filter type, OSR value and
// enable / disable data filter
    Sdfm_configureData_filter(gPeripheralNumber, FILTER1, FILTER_ENABLE, SINC3,
                              OSR_256, DATA_16_BIT, SHIFT_9_BITS);
    Sdfm_configureData_filter(gPeripheralNumber, FILTER2, FILTER_ENABLE, SINC3,
    Sdfm_configureData_filter(gPeripheralNumber, FILTER3, FILTER_ENABLE, SINC3,
    Sdfm_configureData_filter(gPeripheralNumber, FILTER4, FILTER_ENABLE, SINC3,
// Enable Master filter bit: Unless this bit is set none of the filter modules
// can be enabled. All the filter modules are synchronized when master filter
// bit is enabled after individual filter modules are enabled.
    Sdfm_enableMFE(gPeripheralNumber);
// PWM11.CMPC, PWM11.CMPD, PWM12.CMPC and PWM12.CMPD signals cannot
// synchronize the filters. This option is not being used in this example.
    Sdfm_configureExternalreset(gPeripheralNumber,FILTER_1_EXT_RESET_DISABLE,
                                FILTER_2_EXT_RESET_DISABLE,
                                FILTER_3_EXT_RESET_DISABLE,
                                FILTER_4_EXT_RESET_DISABLE);
// Enable interrupts
// Following SDFM interrupts can be enabled / disabled using this function.
//  Enable / disable comparator high threshold
//  Enable / disable comparator low threshold
//  Enable / disable modulator clock failure
//  Enable / disable filter acknowledge
    Sdfm_configureInterrupt(gPeripheralNumber, FILTER1, IEH_DISABLE,
                            IEL_DISABLE, MFIE_DISABLE, AE_ENABLE);
    Sdfm_configureInterrupt(gPeripheralNumber, FILTER2, IEH_DISABLE,
                            IEL_DISABLE, MFIE_DISABLE, AE_DISABLE);
    Sdfm_configureInterrupt(gPeripheralNumber, FILTER3, IEH_DISABLE,
    Sdfm_configureInterrupt(gPeripheralNumber, FILTER4, IEH_DISABLE,
// Enable master interrupt so that any of the filter interrupts can
// trigger by SDFM interrupt to CPU
    Sdfm_enableMIE(gPeripheralNumber);
    while(1);
// Sdfm_configurePins - Configure the SDFM GPIO pins
void Sdfm_configurePins(Uint16 sdfmPinOption)
    Uint16 pin;
    switch (sdfmPinOption)
        case SDFM_PIN_MUX_OPTION1:
            for(pin=16;pin<=31;pin++)
                GPIO_SetupPinOptions(pin, GPIO_INPUT, GPIO_ASYNC);
                GPIO_SetupPinMux(pin,GPIO_MUX_CPU1,7);
            break;
        case SDFM_PIN_MUX_OPTION2:
            for(pin=48;pin<=63;pin++)
            break;
        case SDFM_PIN_MUX_OPTION3:
            for(pin=122;pin<=137;pin++)
            break;
// Cla_initMemoryMap - Initialize Memory map
    EALLOW;
    // Initialize and wait for CLA1ToCPUMsgRAM
    MemCfgRegs.MSGxINIT.bit.INIT_CLA1TOCPU = 1;
    while(MemCfgRegs.MSGxINITDONE.bit.INITDONE_CLA1TOCPU != 1){};
    // Initialize and wait for CPUToCLA1MsgRAM
    MemCfgRegs.MSGxINIT.bit.INIT_CPUTOCLA1 = 1;
    while(MemCfgRegs.MSGxINITDONE.bit.INITDONE_CPUTOCLA1 != 1){};
    // Select LS1 and LS2 RAM to be the programming space for the CLA
    // Select LS5 to be data RAM for the CLA
    MemCfgRegs.LSxMSEL.bit.MSEL_LS0 = 1;
    MemCfgRegs.LSxCLAPGM.bit.CLAPGM_LS0 = 0;
    MemCfgRegs.LSxMSEL.bit.MSEL_LS1 = 1;
    MemCfgRegs.LSxCLAPGM.bit.CLAPGM_LS1 = 0;
    // Filter1 and Filter2 data memory LS2
    MemCfgRegs.LSxMSEL.bit.MSEL_LS2 = 1; //LS2RAM is shared between CPU and CLA
    MemCfgRegs.LSxCLAPGM.bit.CLAPGM_LS2 = 0; // LS2RAM is configured as
                                             // data memory
    // Filter3 and Filter4 data memory LS3
    MemCfgRegs.LSxMSEL.bit.MSEL_LS3 = 1; //LS3RAM is shared between CPU and CLA
    MemCfgRegs.LSxCLAPGM.bit.CLAPGM_LS3 = 0; // LS3RAM is configured as
                                             // data memory
    MemCfgRegs.LSxMSEL.bit.MSEL_LS5 = 1; //LS5RAM is shared between CPU and CLA
    MemCfgRegs.LSxCLAPGM.bit.CLAPGM_LS5 = 1; // LS5RAM is configured as
                                             // program memory
    EDIS;
// CLA_initCpu1Cla - Initialize CLA1 task vectors and end of task interrupts
    // Compute all CLA task vectors
    // On Type-1 CLAs the MVECT registers accept full 16-bit task addresses as
    // opposed to offsets used on older Type-0 CLAs
    EALLOW;
      Cla1Regs.MVECT1 = (uint16_t)(&Cla1Task1);
 //   Cla1Regs.MVECT2 = (uint16_t)(&Cla1Task2);
 //   Cla1Regs.MVECT8 = (uint16_t)(&Cla1Task8);
    // Enable IACK instruction to start a task on CLA in software
    // for all  8 CLA tasks
    asm("   RPT #3 || NOP");
    Cla1Regs.MCTL.bit.IACKE = 1;
    Cla1Regs.MIER.all= 0x0083;
    // Configure the vectors for the end-of-task interrupt for all
    // 8 tasks
    PieVectTable.CLA1_1_INT   = &cla1Isr1;
    PieVectTable.CLA1_2_INT   = &cla1Isr2;
    PieVectTable.CLA1_3_INT   = &cla1Isr3;
    PieVectTable.CLA1_4_INT   = &cla1Isr4;
    PieVectTable.CLA1_5_INT   = &cla1Isr5;
    PieVectTable.CLA1_6_INT   = &cla1Isr6;
    PieVectTable.CLA1_7_INT   = &cla1Isr7;
    PieVectTable.CLA1_8_INT   = &cla1Isr8;
    // Enable CLA interrupts at the group and subgroup levels
    PieCtrlRegs.PIEIER11.all  = 0xFFFF;
    IER |= (M_INT11 );
    EINT;   // Enable Global interrupt INTM
    ERTM;   // Enable Global real time interrupt DBGM
    EDIS;
// cla1Isr1 - CLA1 ISR 1
interrupt void cla1Isr1 () //interrupt which occurs after the routine Cla1Task1 (Filter1)
  int i;
  for(i=0;i<1024;i++){
     vector[i] = Filter1_Result[i];
     if(i>=1024) i=0;
  PieCtrlRegs.PIEACK.all = M_INT11;
// cla1Isr1 - CLA1 ISR 2
interrupt void cla1Isr2 ()
// cla1Isr1 - CLA1 ISR 3
interrupt void cla1Isr3 ()
// cla1Isr1 - CLA1 ISR 4
interrupt void cla1Isr4 ()
// cla1Isr1 - CLA1 ISR 5
interrupt void cla1Isr5 ()
// cla1Isr1 - CLA1 ISR 6
interrupt void cla1Isr6 ()
// cla1Isr1 - CLA1 ISR 7
interrupt void cla1Isr7 ()
// cla1Isr1 - CLA1 ISR 8
interrupt void cla1Isr8 ()
// End of file
The CLA code can't be attached. Then
CLA code:
// \file sdfm_filter_sync.cla
// \brief SDFM filter sync
// \author
// \date
// Group: C2000
// Target Family: F2837xS
// $TI Release: F2837xS Support Library v210 $
// $Release Date: Tue Nov 1 15:35:23 CDT 2016 $
// $Copyright: Copyright (C) 2014-2016 Texas Instruments Incorporated -
// Included Files
#include "F2837xS_cla.h"
#include "F2837xS_piectrl.h"
// Whether MDEBUGSTOP needs to be compiled or not
#define CLA_DEBUG 0
#define PIEACK_GROUP5 0x0010
#pragma DATA_SECTION(Filter1_Result,"Filter1_RegsFile");
#pragma DATA_SECTION(Filter2_Result,"Filter2_RegsFile");
#pragma DATA_SECTION(Filter3_Result,"Filter3_RegsFile");
#pragma DATA_SECTION(Filter4_Result,"Filter4_RegsFile");
short Filter1_Result[MAX_SAMPLES];
short Filter2_Result[MAX_SAMPLES];
short Filter3_Result[MAX_SAMPLES];
short Filter4_Result[MAX_SAMPLES];
short grafico1[MAX_SAMPLES];
short *ptr_graf1[MAX_SAMPLES];
int16 p;
int16 flag;
float gain;
int16 loopCounter1;
// Task 1
__interrupt void Cla1Task1 ( void ) // Interrupt that occurs because SDFM1
gain = (1/327.68);
// if(Sdfm1Regs.SDIFLG.bit.AF1)
Filter1_Result[loopCounter1] = *(Uint16 *)((Uint16)0x5E17); // Stores the result of filter1 at a 1024 samples vector
// Filter2_Result[loopCounter1] = *(Uint16 *)((Uint16)0x5E27);
// Filter3_Result[loopCounter1] = *(Uint16 *)((Uint16)0x5E37);
// Filter4_Result[loopCounter1] = *(Uint16 *)((Uint16)0x5E47);
// GpioDataRegs.GPATOGGLE.bit.GPIO14 = 1;
loopCounter1++; // Counter to the vector filter
ptr_graf1[loopCounter1] = &Filter1_Result[loopCounter1];
Sdfm1Regs.SDIFLGCLR.bit.AF1 = Sdfm1Regs.SDIFLG.bit.AF1; // clear the flag of new data from filter 1
if (loopCounter1 >= 1024){
for(p=0;p<=1024;p++){
grafico1[p] = *ptr_graf1[p]*gain;
loopCounter1 = 0;
Sdfm1Regs.SDIFLGCLR.bit.MIF=1; // clear the flag of global interrupt of the module
__interrupt void Cla1Task2 ( void )
#if (CLA_DEBUG==1)
__mdebugstop();
#endif
// Task 3
__interrupt void Cla1Task3 ( void )
#if (CLA_DEBUG==1)
__mdebugstop();
#endif
// Task 4
__interrupt void Cla1Task4 ( void )
#if (CLA_DEBUG==1)
__mdebugstop();
#endif
// Task 5
__interrupt void Cla1Task5 ( void )
#if (CLA_DEBUG==1)
__mdebugstop();
#endif
// Task 6
__interrupt void Cla1Task6 ( void )
#if (CLA_DEBUG==1)
__mdebugstop();
#endif
// Task 7
__interrupt void Cla1Task7 ( void )
#if (CLA_DEBUG==1)
__mdebugstop();
#endif
// Task 8
__interrupt void Cla1Task8 ( void )
#if (CLA_DEBUG==1)
__mdebugstop();
#endif
// End of file
    Are you trying to say SDFM isn't triggering CLA Task1? (or) SDFM does trigger CLA Task1, but loopCounter1 variable doesn't get incremented as expected?
    Did you already try running below example without any modification? If so, what were your results?
    <C2000Ware>\device_support\f2837xs\examples\cpu1\sdfm_filters_sync_cla\cpu01
    Manoj
    I'm trying to say that SDFM isn't triggering CLA Task1. If I run the original example occurs an error on the debug:
    CPU1_CLA1: Can't Run Target CPU: (Error -2060 @ 0x0) Requested operation cannot be done while device is running. Halt the device, and retry the operation. (Emulation package 8.0.27.9).
    So, i did some modifications similars to a code that run correctly on CPU. This way, there is no error, although the Filter_Result1 doesn't update and the loopCounter1 too.
    Thanks.
  • Marcelo,
    Did you make sure to run the latest version C2000Ware example without any modification?
    Manoj
  • Manoj,
    Unfortunately i'm sure, but this error keeps occurring.
  • Marcelo,
    Thanks for letting us know. I shall file a ticket to look into this issue.
    Please expect a reply from us by this thursday.
    Manoj
  • Marcelo,
    sdfm_filters_sync_cla example code available in C2000Ware (Path: <C2000Ware>\device_support\f2837xs\examples\cpu1\sdfm_filters_sync_cla\cpu01) does work fine and I do get expected output.It is not necessary to connect to CLA to run this project. If everything runs fine, you will see PC stop at cla1Isr1 interrupt and Filter1_Result buffer store the contents of SDFM data filter output.
    I was also able to fix your code after making minor corrections shown below.
    • Example code uses cla1Task8 to clear loopCounter1 and loopCounter2. So, I uncommented below line
    • Since I use cla1Task8 I need to acknowledge it. So, I added below code into cla1Task8 ISR.
    Modified code attached:
    //!       -    OSR = 32
    //!      - OSR = 256
    //!         is available
    // Included Files
    // Defines
    #ifdef __cplusplus
    #endif
    short  vector[1024];
    // Main
    int main(void)
       Uint16  HLT, LLT;
        InitSysCtrl();
        DINT;
    // are cleared.
        InitPieCtrl();
        IER = 0x0000;
        IFR = 0x0000;
        InitPieVectTable();
        EALLOW;
        EDIS;
        EALLOW;
        IER |= M_INT11;
        EINT;
        pinMuxoption = SDFM_PIN_MUX_OPTION1;
        EALLOW;
        EDIS;
        CLA_initCpu1Cla();
        WAITSTEP;
        EALLOW;
        EDIS;
    // Select SDFM1
                                 HLT, LLT);
                                 HLT, LLT);
                                 HLT, LLT);
                                 HLT, LLT);
        while(1);
        Uint16 pin;
                break;
                break;
                break;
        EALLOW;
                                                 // data memory
                                                 // data memory
                                                 // program memory
        EDIS;
        EALLOW;
        // 8 tasks
        IER |= (M_INT11 );
        EDIS;
      int i;
         if(i>=1024) i=0;
    // End of file
    Manoj
  • Can I close this thread? I believe your issue is resolved.
    -Manoj
  • Yes, Manoj. Thank you.
  • Please mark verify answer to the post which resolved your issue. This helps other C2000 engineering community members who have similar questions.
    -Manoj
