Other Parts Discussed in Thread: CONTROLSUITE
I am using ezDSP F28335 board manufactured by Spectrum Digital. And I am using C2000 Embedded Coder in Matlab SIMULINK to download the function blocks in the DSP controller. When I test the board with a simple ePWM module to measure the PWM output, no signal has been detected from the assigned pins though. The DSP is a new board and I am sure it is a good one, not broken, as I have tested several other boards that showed the same result (no output).
I have also tested F28379D Experimenter Kit and F28335 Control Card from Texas Instruments, while the PWM works well with the Matlab SIMULINK downloading process. I saw many boot modes in the user manual and I don't know the difference between the boot modes. But the ezDSP F28335 that I am using is set to SPI-A boot mode as default. Can anyone give me some advice on the problem?
Yafeng
