TMS320F28377D: Flash API hangs on Flash Fapi_setActiveFlashBank execution when ECC enabled
Part Number: TMS320F28377D
Dear all,
I'm developing a project which writes settings into flash using Flash API on TMS320F28377D.
I have followed the instructions provided by TI documents and TI E2E Community.
  1. Power up
  2. Copy interrupts and functions in F021_API_F2837xD_FPU32.lib from flash to .TI.ramfunc using memcpy
  3. Execute InitFlash
  4. Gain pump access
  5. Execute Fapi_InitializeAPI
  6. Execute Fapi_setActiveFlashBank
  7. Fapi_issueProgrammingCommand
Everyting goes fine when debugging but hangs on Step 6 when release.
I add
EALLOW;
Flash0EccRegs.ECC_ENABLE.bit.ENABLE = 0x00;
EDIS;
to close ECC of flash after Step 3 which fixed the problem.
Could anybody tell me how to fix the problem while ECC is enabled?
Bill
  • Dear all,
    I did another experiment. Added
    // Disable ECC of flash
    EALLOW;
    EDIS;
    before step 6 and added
    // Enable ECC of flash
    EALLOW;
    Flash0EccRegs.ECC_ENABLE.bit.ENABLE = 0x0A;
    EDIS;
    after step 6 which made an delicious sandwich.
    Everyting goes well also.
    Could anybody tell me why step 6 can not run while ECC of flash is enabled?
    Bill
    Dear all,
    1. Power up
    4. Gain pump access
    I add
    EALLOW;
    EDIS;
    Bill
  • Bill,
    Please search for "Why is a NMI (due to double bit errors) occurring when Fapi_setActiveFlashBank() is called on F2837xD CPU2?" in Flash wiki at http://processors.wiki.ti.com/index.php/C2000_Flash_FAQ
    Thanks and regards,
    Vamsi
  • Thanks a lot. It's all I want.
