Hello, i need to do a look up table to save a non-sinusoidal wave, i dont know how start, is there a manual or post to folow...
thanks...
thanks...
Hello Arefeen, i have been the examples,,,and I understand them.. thanks...
this use a table SINTB360.ASM, so if I replace the values of my wave in this table i can get my LUT...
my question is... if these procedure the correct solution??
Hello ...there are multiple ways to generate a waveform including lookup table method. The examples work fine to generate a sine wave. If you have a nonsinusoidal but a repeatable waveform (basically has a fixed frequency) then this lookup table method should work for you as well ..... simply replace the sine table with your table representing the nonsinusoidal waveform. The quality of your nonsinusoidal waveform will depend largely on the type of nonsinusoidal waveform, the size of table etc.
