Part Number: TMS320F28032
Hi, I'm Erwin,
I'm the FAE in Shenzhen,
I have a question about the time between the Synchronous signal happened and the value of TBCTR equal TBPHS??
Thank you.
Best Regards
Hi, I'm Erwin,
Thank you.
Best Regards
Hi Erwin,
Can you please give more details about the question? When the sync in signal is received timer counter is loaded with tbphs value and the counter starts counting from there. Are you asking about the time between the syncin signal & and the loading of timer ctr register with the tbphs value?
Vasudha
Hi Erwin,
As per TRM, The value of the phase register is loaded into the counter register when an input synchronization pulse is detected (TBPHS → TBCTR). This operation occurs on the next valid time-base clock (TBCLK) edge. I think the max delay would be 1 TBCLK.
Vasudha
Is the time fixable when switch frequency changes?
What do you mean by switch frequency here ?
Vasudha
