Part Number: TMS320F28377D
Hello everybody ,
I am using dual core F28377D . now everything is working both on CPU1 and CPU2 , I am working on internal Flash
to run a debug session on CPU2 , I manually load CPU1 run it ( to get pin config etc ) than manually connect to CPU2 , load , run adn debug .
I would like to automate this sequence , so to click a command and get CPU1 loaded run then connect to CPU2 etc : how to make this happen ?
how coudl a generate a command sequence for the debugger ?
I m on CCS8 and BlackHawk emulator
thank you very much
regards
Carlo
