Compiler/TMS320F28035: TMS320F28035 download program problem with serial port
Part Number: TMS320F28035
Dear
    When TMS320F28035 uses the serial port to download the program, it is found that the new single-chip microcomputer has not downloaded the program, and the first time after using the serial port to write the program, it cannot be run.
The first time you use the emulator to write the program, you can run it, and then you can run it with the serial port to write the program. What is the problem?
