RTOS: Flash controller TI SYSBIOS
Tool/software: TI-RTOS
Hi, TI!
Could you help me to find description  about settings on screen.
  • Hi Serhii,
    The easiest way to get documentation from XGCONF is to hit the '?' in the top right corner of the page.
    This will open the "cdoc" documentation. This can also be found at <bios_install_dir>/docs/cdoc/index.html. You then navigate to the desire module.
    You can hover over the fields in XGCONF also and get a short description.
    I trick I like to do is use XGCONF to set something and then look at text version of the file via the "cfg Script" tab so you can see the exact field name in question.
    Please treat the "cfg Script" tab as read-only. If you want to edit the file as a text file, open as a text file.
    Todd
  • Hi, ToddMullanix.
    I asked the wrong question, please tell me where there is a description of this particular module. Perhaps it is in a separate literature for SYSBIOS
    In the fact that you have sent a description in general terms.
    Regrads, Serhii/
