Part Number: TMS320F28069
I defined PWM1A as a master:
EALLOW;
/* Assumes ePWM1 clock is already enabled in InitSysCtrl(); */
EPwm1Regs.ETSEL.bit.SOCBEN = 1; /* Enable SOC on B group */
EPwm1Regs.ETSEL.bit.SOCBSEL = 6; /* Select SOC from from CPMB on upcount */
EPwm1Regs.ETPS.bit.SOCBPRD = 1; /* Generate pulse on 1st event */
/* Set period / duty / count mode */
EPwm1Regs.TBPHS.half.TBPHS = 0; /* Set Phase register to zero */
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; /* Phase loading disabled */
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; /* Clock ratio to SYSCLKOUT */
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET; /* Set PWM1A on Zero */
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; /* Clear PWM1A on match on count A up */
EPwm1Regs.AQCTLB.bit.ZRO = AQ_SET; /* Set PWM1B on Zero */
EPwm1Regs.AQCTLB.bit.CBU = AQ_CLEAR; /* Clear PWM1B on match on count B up */
EPwm1Regs.CMPB = DutyCycle_PWMB; /* Set compare B value */
EPwm1Regs.CMPA.half.CMPA = DutyCycle_PWMA; /* Set compare A value */
EPwm1Regs.TBPRD = PERIOD; /* Set period for ePWM1 */
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; /* Count up and start */
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD;
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // sync "down-stream"
EDIS;
and I want to generate a PWM compementary signals on PWM3:
/* Assumes ePWM3 clock is already enabled in InitSysCtrl(); */
EALLOW;
/*PWM3: Set period / duty / count mode */
EPwm3Regs.TBPHS.half.TBPHS = 0; /* Set Phase register to zero */
EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE; /* Phase loading disabled */
EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; /* Clock ratio to SYSCLKOUT */
EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm3Regs.AQCTLA.bit.ZRO = AQ_SET; /* Set PWM3A on Zero */
EPwm3Regs.AQCTLA.bit.CAU = AQ_CLEAR; /* Clear PWM3A on match on count A up */
EPwm3Regs.AQCTLB.bit.ZRO = AQ_SET; /* Set PWM3B on Zero */
EPwm3Regs.AQCTLB.bit.CBU = AQ_CLEAR; /* Clear PWM3B on match on count B up */
//EPwm3Regs.CMPB = DutyCycle_PWMB; /* Set compare B value */
EPwm3Regs.CMPA.half.CMPA =DutyCycle_PWMA; /* Set compare A value */
EPwm3Regs.TBPRD = PERIOD; /* Set period for ePWM3 */
EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; /* Count up and start */
EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD;
EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // sync "down-stream" slave
EDIS;
/* Configure trip zone based on Comparator 3 output and configure blanking */
EALLOW;
EPwm3Regs.TZSEL.bit.DCAEVT2 = 0; /* Digital compare, output A, cycle by cycle */
EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO; /* EPWM3A will go low */
EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_HI; /* EPWM3B goes HI */
EPwm3Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT; // DCAH = Comparator 1 output
EPwm3Regs.TZDCSEL.bit.DCAEVT2 = TZ_DCAH_HI; /* DCAEVT2 = DCAL High (will become active as Comparator output goes High) */
/* DCAEVT2 = DCAH high (will become EPwm1Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP2OUT; DCAH = Comparator 2 output*/
EPwm3Regs.DCACTL.bit.EVT2SRCSEL = DC_EVT2; /* DCAEVT2 = DCAEVT2 (not filtered) */
EPwm3Regs.DCACTL.bit.EVT2FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
EPwm3Regs.DCFCTL.bit.PULSESEL = 0; /* Time-base counter equal to period (TBCTR =TBPRD) */
EPwm3Regs.DCFCTL.bit.BLANKINV = 0; /* Blanking window inverted */
EPwm3Regs.DCFCTL.bit.BLANKE = 1; /* Blanking Window Enable */
EPwm3Regs.DCFCTL.bit.SRCSEL = 0; /* Source Is DCAEVT1 Signal */
EPwm3Regs.DCFWINDOW = 0; //34; /* length blanking window: this corresponds to: 34*11.1ns=377.4ns*/
EPwm3Regs.DCFOFFSET = 5; /* 5*11.1=55.5ns blanking window offset & then blanking window begins */
EDIS;
// Active high complementary PWMs - Set up the deadband
EPwm3Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm3Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm3Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
EPwm3Regs.DBRED = 0;//15;
EPwm3Regs.DBFED = 0;//15;
However, after I run my code I could only see channel 3B on the scope but not channel B. I made sure PWM3 GPIOs are configured properly.
Can anyone, tell me why is that happening?
