Part Number: TMS320F28377D
Hi expert,
My customer debugging F28377D on their custom board. After they debug the code once in flash memory successfully, the debugger will not do this again with below error message given.
C28xx_CPU1: Trouble Writing Memory Block at 0x5f452 on Page 1 of Length 0x1: (Error -1041 @ 0x5F453) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.0.27.9)
C28xx_CPU1: GEL: Error while executing OnTargetConnect(): Target failed to write 0x0005F452@Data
at *((int *) 0x5F452)=0xFFFF [f28377s.gel:82]
at OnTargetConnect()
C28xx_CPU1: Error: (Error -1135 @ 0x8E286) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.0.27.9)
C28xx_CPU1: Failed CPU Reset
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
They are using CCS 8.2 with debugger connection test successfully passed. Do you have any idea on this?
Sheldon
