Could I supplied voltage using the 3.3 V and gnd pines of the piccolo? I guess i saw some post about this but now i can´t find it
Gastón
Gastón
Can I supply the voltage to the piccolo ( by using the 3.3V pin and GND) instead using the USB port?
Gastón
Gaston said:Can I supply the voltage to the piccolo ( by using the 3.3V pin and GND) instead using the USB port?
Gastón
Which board, Gaston?
-Lori
Gaston,
Assuming this is a Docking Station, there is a power jack on the board itself that can be used instead of powering from USB. You supply 5v to the jack and it regulates down. We don't have a hook for you to supply the 3.3 directly.
-Lori
Lori:
I have the piccolo control stick ( $ 39 ) https://estore.ti.com/TMDX28027USB-TMX320F28027-Piccolo-controlSTICK-P1464.aspx
thanks Lori
Gastón
