Part Number: F28M36P63C2
Other Parts Discussed in Thread: CONTROLSUITE
Tool/software: TI-RTOS
Hello
Now i have a qusetion about low power mode of F28M36P63C2.
I want to into the low power mode when i push the key, but when i use the "wfi" command in my task, it is don't into the low power mode.
So I want to test the demo source(Sleep_Low_Power_Mode_Wakeup) in "controlSUITE", but when i bulid the "C28" project, there is some error like below:
Do you have any sugestion about low power mode of F28M36P63C2?
<Linking>
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 46: error:
RAML0 memory range has already been specified
RAML0 memory range overlaps existing memory range RAML0
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 47: error:
RAML1 memory range has already been specified
RAML1 memory range overlaps existing memory range RAML1
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 64: error:
BEGIN memory range has already been specified
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 69: error:
FPUTABLES memory range has already been specified
FPUTABLES memory range overlaps existing memory range FPUTABLES
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 70: error:
IQTABLES memory range has already been specified
IQTABLES memory range overlaps existing memory range IQTABLES
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 71: error:
IQTABLES2 memory range has already been specified
IQTABLES2 memory range overlaps existing memory range IQTABLES2
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 72: error:
IQTABLES3 memory range has already been specified
IQTABLES3 memory range overlaps existing memory range IQTABLES3
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 74: error:
BOOTROM memory range has already been specified
BOOTROM memory range overlaps existing memory range BOOTROM
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 76: error:
RESET memory range has already been specified
RESET memory range overlaps existing memory range RESET
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 82: error:
BOOT_RSVD memory range has already been specified
BOOT_RSVD memory range overlaps existing memory range BOOT_RSVD
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 84: error:
RAMM1 memory range has already been specified
RAMM1 memory range overlaps existing memory range RAMM1
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 85: error:
RAML2 memory range has already been specified
RAML2 memory range overlaps existing memory range RAML2
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 86: error:
RAML3 memory range has already been specified
RAML3 memory range overlaps existing memory range RAML3
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 88: error:
CTOMRAM memory range has already been specified
CTOMRAM memory range overlaps existing memory range CTOMRAM
"C:/ti/controlSUITE/device_support/f28m36x/v208/F28M36x_common/cmd/F28M36x_generic_C28_FLASH.cmd", line 89: error:
MTOCRAM memory range has already been specified
MTOCRAM memory range overlaps existing memory range MTOCRAM
error: errors encountered during linking; "LPM_Idle_c28.out" not built
>> Compilation failure
makefile:145: recipe for target 'LPM_Idle_c28.out' failed
gmake: *** [LPM_Idle_c28.out] Error 1
gmake: Target 'all' not remade because of errors.
