The code runs well in RAM boot mode. The code is modified to boot from Flash.
the following codes are inserted to RAM code:
These three definitions are inserted before main{}
// These are defined by the linker (see F28335.cmd)
extern Uint16 RamfuncsLoadStart;
extern Uint16 RamfuncsLoadEnd;
extern Uint16 RamfuncsRunStart;
//extern Uint16 RamfuncsLoadSize;
//These code are inserted after initPieVecTable();
// The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart
// symbols are created by the linker. Refer to the F28335.cmd file.
// memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (Uint32)&RamfuncsLoadSize);
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (Uint32)&RamfuncsLoadEnd);
// Call Flash Initialization to setup flash waitstates
// This function must reside in RAM
InitFlash();
When build the project, it gives the memory violation messages, as the following.
My two questions:
1. memcpy() is a wrong function name. the right name is memcopy(). However, system does not recognize the right name memcopy. Why?
2. What is the violated in mapping the memory?
Thank you.
"../F28335.cmd", line 78: error #10263: RAML0 memory range has already been specified
"../F28335.cmd", line 78: error #10264: RAML0 memory range overlaps existing memory range RAML0
"../F28335.cmd", line 79: error #10264: RAML1 memory range overlaps existing memory range RAML1L2
"../F28335.cmd", line 80: error #10264: RAML2 memory range overlaps existing memory range RAML1L2
"../F28335.cmd", line 81: error #10263: RAML3 memory range has already been specified
"../F28335.cmd", line 81: error #10264: RAML3 memory range overlaps existing memory range RAML3
"../F28335.cmd", line 83: error #10264: ZONE7 memory range overlaps existing memory range ZONE7A
"../F28335.cmd", line 91: error #10263: CSM_RSVD memory range has already been specified
"../F28335.cmd", line 91: error #10264: CSM_RSVD memory range overlaps existing memory range CSM_RSVD
"../F28335.cmd", line 92: error #10263: BEGIN memory range has already been specified
"../F28335.cmd", line 93: error #10263: CSM_PWL memory range has already been specified
"../F28335.cmd", line 93: error #10264: CSM_PWL memory range overlaps existing memory range CSM_PWL
"../F28335.cmd", line 95: error #10263: ADC_CAL memory range has already been specified
"../F28335.cmd", line 95: error #10264: ADC_CAL memory range overlaps existing memory range ADC_CAL
"../F28335.cmd", line 97: error #10263: IQTABLES memory range has already been specified
"../F28335.cmd", line 97: error #10264: IQTABLES memory range overlaps existing memory range IQTABLES
"../F28335.cmd", line 98: error #10263: IQTABLES2 memory range has already been specified
"../F28335.cmd", line 98: error #10264: IQTABLES2 memory range overlaps existing memory range IQTABLES2
"../F28335.cmd", line 99: error #10263: FPUTABLES memory range has already been specified
"../F28335.cmd", line 99: error #10264: FPUTABLES memory range overlaps existing memory range FPUTABLES
"../F28335.cmd", line 100: error #10264: ROM memory range overlaps existing memory range BOOTROM
"../F28335.cmd", line 101: error #10263: RESET memory range has already been specified
"../F28335.cmd", line 101: error #10264: RESET memory range overlaps existing memory range RESET
"../F28335.cmd", line 110: error #10263: RAMM1 memory range has already been specified
"../F28335.cmd", line 110: error #10264: RAMM1 memory range overlaps existing memory range RAMM1
"../F28335.cmd", line 111: error #10263: RAML4 memory range has already been specified
"../F28335.cmd", line 111: error #10264: RAML4 memory range overlaps existing memory range RAML4
"../F28335.cmd", line 112: error #10263: RAML5 memory range has already been specified
"../F28335.cmd", line 112: error #10264: RAML5 memory range overlaps existing memory range RAML5
"../F28335.cmd", line 113: error #10263: RAML6 memory range has already been specified
"../F28335.cmd", line 113: error #10264: RAML6 memory range overlaps existing memory range RAML6
"../F28335.cmd", line 114: error #10263: RAML7 memory range has already been specified
"../F28335.cmd", line 114: error #10264: RAML7 memory range overlaps existing memory range RAML7
warning #10247-D: creating output section "DLOG" without a SECTIONS specification
error #10010: errors encountered during linking; "FlashRun_pmsm28335.out" not built
