Part Number: F28M36P63C2
Is there a easy way to change the endianness of the 32 bit data words in the HEX file?
I see there are options in the HEX utility but I returns errors.
thanks again.
thanks again.
Are you using the hex utility on an executable for the C28x CPU, or the ARM CPU? Which hex utility options did you use? What errors did you see? Are the errors diagnostics from the hex utility, or incorrect hex utility output?
Thanks and regards,
-George
