I have a question about example "f28069_sci_flash_kernel".
When I flash DSP using serial flash programmer (flash kernel A), the all sectors of the flash are erased before the new application will be programmed. Is it right?
I see that only the sectors A,B,C and D are erased. Is it right? Why doesn't the flash kernel erase the sectors E,F,G and H?
Can I used serial flash programmer (flash kernel B) for F28069? If it's possible, what should I do?
Thank you for your support in advance!
