Part Number: TMS320F280049
Hi, Devin,
Thanks for your response.
Customer added the register definition in header file by themselves and made the debugging worked, while you do have an update on the C2000WARE update?
In the other hand, they met new problem when using this feature as the ADC result seems to be incorrect when it's enabled.
Channel A9 is left unconnected and will be sampled. When ADCOSDETECT is configured to 3/4/5/6/7, the ADCRESULT will be 1591/2259/0/3868/0, where pull down seems to work, while pull up and resistor divider seems to get smaller results.
Could you please take a look at this issue and suggest where the problem is?
Ricky Zhang
