CCS/TMS320F28335: ADC results plotting graph is not coming proper as per the given inputs
Part Number: TMS320F28335
I am using EZDSP TMS320F28335 board for the controller peripheral testing. I am testing ADC code for sine wave and square wave (0-2V @ 2KHz) as input .
I am using code in C2000Ware C:\ti\C2000Ware_1_00_05_00_Software\device_support\f2833x\examples\adc_soc . for plotting ADC readings I have converted digital results back to analog input using below line of code.
Another change, I have defined Voltage1[1000] sample array instead of 10 samples. The result plotted in graph coming as below.
As you can see the waveform is not coming as smooth values. Is there any way with which I can get better results and resolution. Please provide your inputs on same.
Namita
