Part Number: TMS320F28069F
Other Parts Discussed in Thread: TMDSHVMTRINSPIN,
We purchased the TMDSHVMTRINSPIN development kit.
Our target application is the sensorless Field Oriented Control of ACI motor.
We are currently designing our prototype for an ACIM inverter/controller by using the TMS320F28069F DSP.
My question is on the configuration for the phase current sensing.
I have found out that the TMDSHVMTRINSPIN development kit uses the low-side three shunt sensing configuration.
Meanwhile we have found out that the phase current may be able to be measured by using the isolated hall sensor IC at the high side.
Is there any merit if I use the isolated hall sensor ICs at the high side to measure the phase currents for our prototype design which employs the TMS320F28069F DSP?
Otherwise does TI recommend to use the low-side three shunt sensing configuration as in the TMDSHVMTRINSPIN development kit.
Of course I know well that the material cost would go up if I use the isolated hall sensor ICs at the high side to measure the phase currents for our prototype design.
Thank you for your guidance.
With regards,
G. Kim
