RTOS/LAUNCHXL-F28069M: GateMutexPri Example
Part Number: LAUNCHXL-F28069M
Tool/software: TI-RTOS
Can you please provide an example project that uses GateMutexPri to demonstrate a solution to concurrent-access model?
Thanks!
  • Hello! We're getting your post assigned to a TI-RTOS expert. Someone will get back to you soon. Thanks for your patience.
    Whitney
  • Hi Louis,
    I took the mutex example from SYS/BIOS and tweaked it to use a GateMutexPri instance instead of a Semaphore. The lower priority spins for longer than the higher priority sleeps. When the higher priority tries to enter the gate, the lower priority task has it's priority raised. I also had to add the following into the .cfg of the example
    var GateMutexPri = xdc.useModule('ti.sysbios.gates.GateMutexPri');
     * Copyright (c) 2015-2019, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  ======== mutex.c ========
    /* XDC module Headers */
    #include <xdc/std.h>
    #include <xdc/runtime/Error.h>
    #include <xdc/runtime/System.h>
    /* BIOS module Headers */
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Clock.h>
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/knl/Semaphore.h>
    #include <ti/sysbios/gates/GateMutexPri.h>
    #define TASKSTACKSIZE   512
    Void task1Fxn(UArg arg0, UArg arg1);
    Void task2Fxn(UArg arg0, UArg arg1);
    Int resource = 0;
    Int finishCount = 0;
    UInt32 sleepTickCount;
    Task_Struct task1Struct, task2Struct;
    Char task1Stack[TASKSTACKSIZE], task2Stack[TASKSTACKSIZE];
    Semaphore_Struct semStruct;
    Semaphore_Handle semHandle;
    GateMutexPri_Handle gateHandle;
     *  ======== main ========
    int main()
        /* Construct BIOS objects */
        Task_Params taskParams;
        Semaphore_Params semParams;
        Error_Block eb;
        Error_init(&eb);
        gateHandle = GateMutexPri_create(NULL, &eb);
        /* Construct writer/reader Task threads */
        Task_Params_init(&taskParams);
        taskParams.stackSize = TASKSTACKSIZE;
        taskParams.stack = &task1Stack;
        taskParams.priority = 1;
        Task_construct(&task1Struct, (Task_FuncPtr)task1Fxn, &taskParams, NULL);
        taskParams.stack = &task2Stack;
        taskParams.priority = 2;
        Task_construct(&task2Struct, (Task_FuncPtr)task2Fxn, &taskParams, NULL);
        /* Construct a Semaphore object to be use as a resource lock, inital count 1 */
        Semaphore_Params_init(&semParams);
        Semaphore_construct(&semStruct, 1, &semParams);
        /* Obtain instance handle */
        semHandle = Semaphore_handle(&semStruct);
        /* We want to sleep for 10000 microseconds */
        sleepTickCount = 10000 / Clock_tickPeriod;
        BIOS_start();    /* Does not return */
        return(0);
     *  ======== task1Fxn ========
        UInt32 time;
        IArg key;
        for (;;) {
            System_printf("Running task1 function\n");
    //        if (Semaphore_getCount(semHandle) == 0) {
    //            System_printf("Sem blocked in task1\n");
            /* Get access to resource */
    //        Semaphore_pend(semHandle, BIOS_WAIT_FOREVER);
            key = GateMutexPri_enter(gateHandle);
            /* Do work by waiting for 2 system ticks to pass */
            time = Clock_getTicks();
            while (Clock_getTicks() <= (time + sleepTickCount)) {
            /* Do work on locked resource */
            resource += 1;
            /* Unlock resource */
    //        Semaphore_post(semHandle);
            GateMutexPri_leave(gateHandle, key);
            Task_sleep(sleepTickCount);
     *  ======== task2Fxn ========
        IArg key;
        for (;;) {
            System_printf("Running task2 function\n");
    //            System_printf("Sem blocked in task2\n");
            resource += 1;
            finishCount++;
            if (finishCount == 5) {
                System_printf("Calling BIOS_exit from task2\n");
                BIOS_exit(0);
    Todd
  • Thank you, Todd, for the example.
