CCS/DRV8312-69M-KIT: lab 11e not working Hall sensor start-up with transition to FAST for InstaSPIN-FOC
Part Number: DRV8312-69M-KIT
Other Parts Discussed in Thread: MOTORWARE
Hi
i am trying to run lab 11e with the kit DRV8312-69M-KIT, it does compile and open the debug window  enable the real time debugger , click the run button  set gMotorVars.Flag_enableSys and gMotorVars.Flag_Run_Identify  to 1 the connection with the microcontroler gets lost and stops working, the kit is working with other labs (lab 2, 4, 4a, 5a, 11)  they run with no issues but when trying to run lab 11e the connection gets lost
i am using the default code found in C:\ti\motorware\motorware_1_01_00_18\sw\solutions\instaspin_foc\boards\drv8312kit_revD\f28x\f2806xF\projects\ccs\proj_lab11e with no modification, i am connecting the hall sensors to the J4 with the hall sensor A connected to pin 1, sensor B connected to pin2, sensor C connected to pin 3 and the 5 and gnd connected to the hall sensors, i am using ccs 9.0, i also tried to use the universal gui after building the file but it does not work either,
i set all the motor parameters and offsets for current and voltage.
Any help will be greatly appreciated.
best regards
Jorge
