Part Number: TMS320F28379D
Hi everyone,
I discussed this issue before. Didn't receive any response. I am trying to run the example "adc_soc_software_cpu01.c". The results i am getting in the ADC Result Regs (A2,A3,B2,B3). The issue is whenever i change the analog value on ADC Channel A2, it gives ADC Result A2 Value accordingly but at the same time changing the ADC Result A3 Value at some extent. The same thing happens vice versa and when i am using ADC B Channels. I have added some screen shots that may help you. In some cases, when ADC Channel A2 is disconnected and A3 is connected, there will still be some value at A2 which varies when i change the analog value at channel A3. Help needed.
In this screen shot, there is nothing connected at AdcaResult0 and AdcbResult1, but still there are some values which changes as i vary AdcaResult1 AdcbResult0.
