Part Number: TMS320F28069F
we experience an issue with dynamic switching of the ADC reference between external and internal (bandgap) reference. After changing reference using ADCREFSEL it seems like the controller does not actually use the different source for the reference.
Browsing the forum I found the following answer from Matthew Pate to a related question ( https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/54326 )
"You can dynamically switch between internal/ext ref to accomodate different inputs, but you will need to give some settling time in this case after the switch, I think 100us would be OK, but I need to follow up on this aspect."
Is there any documentation where this fact is stated or further explained? Is the given answer also valid for the F28069 and what settling time is really needed to switch between the references?
Wolfgang
