Hi ,
I designed my own 28377d minimum system board, and it doesn’t work. I guess I have some trouble in power supply.
The minimum system board can connect to ccs and run the demo program. But after a while,problems arose.I found at first, the value between 1.2v and 3.3v was around 10k, when pass on DC, the value reduced to almost zero quickly, which means short circuit between 1.2v and 3.3v. Turn off the power and the value will slowly Restored to 10k, but the board can not connect ccs yet, which means the chip has broken.
The 3.3v and 1.2v are come from two switching power management chip separately, I try to supply 3.3v alone and supply 3.3v and 1.2v both, and have same problem at last.
Thanks & regards,
Docata
