Part Number: TMDSCNCD28M36
Hi this is a electronic troll again plz see my beautiful problem
before)
after loading M3
yes and the problem is i have nothing idea about whatsgoingon
and the last error code quote
Cortex_M3_0: GEL Output: Memory Map Initialization Complete
Cortex_M3_0: GEL Output: Flash programming on Rev E/Rev F (device revision) onwards needs TI C2000 Device support package v4.1.4.3 or newer. Make sure to check and install the updates!
Cortex_M3_0: GEL Output: Watchdog Timers Enabled
Cortex_M3_0: GEL Output: UARTs Enabled
C28xx_0: GEL Output:
RAM Initialization Complete
C28xx_0: Error: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 8.1.0.00007)
C28xx_0: Unable to determine target status after 20 attempts
C28xx_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
