Part Number: TMS320F28379D
I have locked the device and to debug the code, I place the TI boot loader into the WAIT mode.
After unlocking the device via the CCS debugger, I set a break point at the start address (0x80000). However, pressing the continue button, causes the following error:
C28xx_CPU1: Error: (Error -1135 @ 0x3FF16A) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 8.1.0.00007)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Breakpoint Manager: Unable to remove requested AET job
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
How can I continue debugging after unlocking the device?
