LAUNCHXL-F280049C: PWM Signal reading by using a terminal
Part Number: LAUNCHXL-F280049C
Hi! I'm pretty new to the microprocessors and I'm wondering, how do I read a PWM signal bu using a terminal? I believe it has something to do with SCI but I have no idea. Can you help me out?
  • hi ,
    I believe the epwm and the sci are not related .
    SCI is capable of sending / receiving any data packed in the format expected by the module
    When you mean read epwm signals are you referring to reading the time base counter values ?
    For EPWM you can check the example available here :
    C2000Ware\driverlib\f28004x\examples\epwm
    For SCI you could look at example here :
    C2000Ware\driverlib\f28004x\examples\sci
    Regards.
