CCS/TMS320F28335: ePWM5A and 5B not giving output
Part Number: TMS320F28335
Dear Sir, madam,
I have initialized ePWM5A and 5B as follows
void Gpio_setup1(void){
    EALLOW;
    GpioCtrlRegs.GPAPUD.bit.GPIO0 = 0;   // Enable pullup on GPIO0
    GpioCtrlRegs.GPAPUD.bit.GPIO1 = 0;   // Enable pullup on GPIO1
    GpioCtrlRegs.GPAPUD.bit.GPIO2 = 0;   // Enable pullup on GPIO0
    GpioCtrlRegs.GPAPUD.bit.GPIO3 = 0;   // Enable pullup on GPIO1
    GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1;  // GPIO0 = PWM1A
    GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1;  // GPIO1 = PWM1B
    GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 1;  // GPIO0 = PWM2A
    GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 1;  // GPIO1 = PWM2B
    GpioCtrlRegs.GPAMUX1.bit.GPIO4 = 1;  // GPIO0 = PWM3A
    GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 1;  // GPIO1 = PWM3B
    GpioCtrlRegs.GPAMUX1.bit.GPIO6 = 1;  // GPIO0 = PWM4A
    GpioCtrlRegs.GPAMUX1.bit.GPIO7 = 1;  // GPIO1 = PWM4B
    GpioCtrlRegs.GPAMUX1.bit.GPIO8 = 1;  // GPIO0 = PWM5A
    GpioCtrlRegs.GPADIR.bit.GPIO8=1;
    GpioCtrlRegs.GPAMUX1.bit.GPIO9 = 1;  // GPIO1 = PWM5B
    GpioCtrlRegs.GPADIR.bit.GPIO9=1;
    GpioCtrlRegs.GPAMUX2.bit.GPIO30 = 0;
    GpioCtrlRegs.GPADIR.bit.GPIO30 = 1;
    EDIS;
void InitEPwm1Example(void)
    // Setup TBCLK
    //EPWM1 A and B are GPIO 0 and 1
    EPwm1Regs.TBCTL.bit.CTRMODE = 0; // Count up down
    EPwm1Regs.TBPRD = 3750;       // Set timer period
    EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;    // Disable phase loading
    EPwm1Regs.TBPHS.half.TBPHS = 0x0000;       // Phase is 0
    EPwm1Regs.TBCTR = 0x0000;                  // Clear counter
    EPwm1Regs.TBCTL.bit.HSPCLKDIV = 001;   // Clock ratio to SYSCLKOUT
    EPwm1Regs.TBCTL.bit.CLKDIV = 000;
    EPwm1Regs.TBCTL.bit.SYNCOSEL=1;
    EPwm1Regs.CMPA.half.CMPA =1875;    // Set compare A value
    EPwm1Regs.CMPB = 1875;              // Set Compare B value
    EPwm1Regs.DBCTL.bit.OUT_MODE=3;
    EPwm1Regs.DBCTL.bit.POLSEL=2;
    EPwm1Regs.DBCTL.bit.IN_MODE=0;
    EPwm1Regs.DBRED=50;
    EPwm1Regs.DBFED=50;
    EPwm1Regs.AQCTLA.bit.CAU=2;    // Set PWM1A on Zero
    EPwm1Regs.AQCTLA.bit.PRD=1;
    EPwm1Regs.AQCTLB.bit.CBU=2;
    EPwm1Regs.AQCTLB.bit.PRD=1;
    EPwm1Regs.ETSEL.bit.SOCAEN = 1;     // Enable SOC on A group
    EPwm1Regs.ETSEL.bit.SOCASEL = 4;    // Select SOC from from CPMA on upcount
    EPwm1Regs.ETPS.bit.SOCAPRD = 1;     // Generate pulse on 1st event
    EPwm2Regs.TBCTL.bit.CTRMODE = 0; // Count up down
    EPwm2Regs.TBPRD = 3750;       // Set timer period
    EPwm2Regs.TBCTL.bit.PHSEN = 1;    // Disable phase loading
    EPwm2Regs.TBPHS.half.TBPHS = 0;       // Phase is 0
    EPwm2Regs.TBCTL.bit.PHSDIR=0;
    EPwm2Regs.TBCTR = 0x0000;                  // Clear counter
    EPwm2Regs.TBCTL.bit.HSPCLKDIV = 001;   // Clock ratio to SYSCLKOUT
    EPwm2Regs.TBCTL.bit.CLKDIV = 000;
    EPwm2Regs.TBCTL.bit.SYNCOSEL=0;
    EPwm2Regs.CMPA.half.CMPA =1875;    // Set compare A value
    EPwm2Regs.CMPB = 1875;              // Set Compare B value
    EPwm2Regs.DBCTL.bit.OUT_MODE=3;
    EPwm2Regs.DBCTL.bit.POLSEL=2;
    EPwm2Regs.DBCTL.bit.IN_MODE=0;
    EPwm2Regs.DBRED=50;
    EPwm2Regs.DBFED=50;
    EPwm2Regs.AQCTLA.bit.CAU=2;    // Set PWM1A on Zero
    EPwm2Regs.AQCTLA.bit.PRD=1;
    EPwm2Regs.AQCTLB.bit.CBU=2;
    EPwm2Regs.AQCTLB.bit.PRD=1;
    EPwm3Regs.TBCTL.bit.CTRMODE = 2; // Count up down
    EPwm3Regs.TBPRD = 1875;       // Set timer period
    EPwm3Regs.TBCTL.bit.PHSEN = 1;    // Disable phase loading
    EPwm3Regs.TBPHS.half.TBPHS = 0;       // Phase is 0
    EPwm3Regs.TBCTL.bit.PHSDIR=0;
    EPwm3Regs.TBCTR = 0x0000;                  // Clear counter
    EPwm3Regs.TBCTL.bit.HSPCLKDIV = 001;   // Clock ratio to SYSCLKOUT
    EPwm3Regs.TBCTL.bit.CLKDIV = 000;
    EPwm3Regs.TBCTL.bit.SYNCOSEL=0;
    EPwm3Regs.CMPA.half.CMPA =937;    // Set compare A value
    EPwm3Regs.CMPB = 937;              // Set Compare B value
    EPwm3Regs.DBCTL.bit.OUT_MODE=3;
    EPwm3Regs.DBCTL.bit.POLSEL=2;
    EPwm3Regs.DBCTL.bit.IN_MODE=0;
    EPwm3Regs.DBRED=50;
    EPwm3Regs.DBFED=50;
    EPwm3Regs.AQCTLA.bit.CAU=2;    // Set PWM1A on Zero
    EPwm3Regs.AQCTLA.bit.CAD=1;
    EPwm3Regs.AQCTLB.bit.CBU=2;
    EPwm3Regs.AQCTLB.bit.CBD=1;
    EPwm4Regs.TBCTL.bit.CTRMODE = 2; // Count up down
    EPwm4Regs.TBPRD = 1875;       // Set timer period
    EPwm4Regs.TBCTL.bit.PHSEN = 1;    // Disable phase loading
    EPwm4Regs.TBPHS.half.TBPHS = 0;       // Phase is 0
    EPwm4Regs.TBCTL.bit.PHSDIR=0;
    EPwm4Regs.TBCTR = 0x0000;                  // Clear counter
    EPwm4Regs.TBCTL.bit.HSPCLKDIV = 001;   // Clock ratio to SYSCLKOUT
    EPwm4Regs.TBCTL.bit.CLKDIV = 000;
    EPwm4Regs.TBCTL.bit.SYNCOSEL=0;
    EPwm4Regs.CMPA.half.CMPA =937;    // Set compare A value
    EPwm4Regs.CMPB = 937;              // Set Compare B value
    EPwm4Regs.DBCTL.bit.OUT_MODE=3;
    EPwm4Regs.DBCTL.bit.POLSEL=2;
    EPwm4Regs.DBCTL.bit.IN_MODE=0;
    EPwm4Regs.DBRED=50;
    EPwm4Regs.DBFED=50;
    EPwm4Regs.AQCTLA.bit.CAU=2;    // Set PWM1A on Zero
    EPwm4Regs.AQCTLA.bit.CAD=1;
    EPwm4Regs.AQCTLB.bit.CBU=2;
    EPwm4Regs.AQCTLB.bit.CBD=1;
    EPwm5Regs.TBCTL.bit.CTRMODE = 0; // Count up down
    EPwm5Regs.TBPRD = 3750;       // Set timer period
    EPwm5Regs.TBCTL.bit.PHSEN = 1;    // Disable phase loading
    EPwm5Regs.TBPHS.half.TBPHS = 0;       // Phase is 0
    EPwm5Regs.TBCTL.bit.PHSDIR=0;
    EPwm5Regs.TBCTR = 0x0000;                  // Clear counter
    EPwm5Regs.TBCTL.bit.HSPCLKDIV = 001;   // Clock ratio to SYSCLKOUT
    EPwm5Regs.TBCTL.bit.CLKDIV = 000;
    EPwm5Regs.TBCTL.bit.SYNCOSEL=0;
    EPwm5Regs.CMPA.half.CMPA =1875;    // Set compare A value
    EPwm5Regs.CMPB = 1875;              // Set Compare B value
    EPwm5Regs.DBCTL.bit.OUT_MODE=3;
    EPwm5Regs.DBCTL.bit.POLSEL=2;
    EPwm5Regs.DBCTL.bit.IN_MODE=0;
    EPwm5Regs.DBRED=50;
    EPwm5Regs.DBFED=50;
    EPwm5Regs.AQCTLA.bit.CAU=2;    // Set PWM1A on Zero
    EPwm5Regs.AQCTLA.bit.PRD=1;
    EPwm5Regs.AQCTLB.bit.CBU=2;
    EPwm5Regs.AQCTLB.bit.PRD=1;
In the main program, I called these two functions. All ePWMs are working fine except ePWM5A and 5B. Do, I need to change any other settings. Please help me in this regard.
