Other Parts Discussed in Thread: BQ32002, C2000WARE
Hi,I am trying to interface bq32002 rtc with TMS320F28069 using I2C .
so,anybody can guide me please?
Thank you
Thank you
Hi Mihir,
Are you needing help with Hardware, Software, or both for interfacing with the board?
Please reference the BQ32002 datasheet for details on HW setup/considerations and the required data format the device expects when being written to or read from.
For software help I'd suggest referencing the i2c_eeprom example within C2000ware, located at the directory below:
C:\ti\c2000\C2000Ware_2_00_00_02\device_support\f2806x\examples\c28\i2c_eeprom
This is an interrupt driven i2c example for interfacing with an eeprom slave. You will need to edit the software to fit your slave device and application. For a more straight-forward SW example to work off of you can look at what I provided in the below E2E post. Simple functions for reading/writing to i2c slave registers are included:
https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/773846
Kevin
