Part Number: DRV8312-C2-KIT
Other Parts Discussed in Thread: CONTROLSUITE
Hey,
I would like to know, why the hole "GUI_project_InstaSPIN_BLDC" is working with PU quantities.
Thanks in advance,
Sarah
Hey,
Thanks in advance,
Sarah
All motor control projects in controlSUITE are working with PU format, the calculations are simplified because quantities expressed as per-unit do not change when these values are referred from one side of a transformer to the others, especially on the fixed-point controllers.
Hey,
thanks for answer.
But I don't understand what you mean by "from one side of a transformer to the others".
Which transformer do you mean?
Thanks in advance,
Sarah
You may have a look at some papers about the Per-Unit as the following links that should help you to understand why to use the PU for motor control on a fixed point controller, the PU system will help to simplify the calculation and transform in a project.
https://peguru.com/2011/06/per-unit-system-practice-problem-solved-for-easy-understanding/
