CCS/TMS320F28075: Getting messy code when trying to save flash memory via CCS
Part Number: TMS320F28075
Hi team,
In order to debug for customer, I am trying to export their Flash map via CCS.
1.To do this, I connect the target and choose save memory.
2.Then I chose the file type to be Binary and create a .bin file
3.Start Address : 0x80000
   Memory Page: Program
   Length in Words: 0x10000
4. Chose finish to generate the file.
No matter I try to open the .bin file with notepad++ or windows notepad, I can only get messy code.
The file generated is attached.
I remembered I performed the same process in customer side before and it worked. Did I do anything wrong to get the file?
Brianhttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/171/1.7z
  • Hi Brian,
    Are you trying to load the image in a different board or do you want to read the file content?
    The .bin file is not readable format in notepad++. Can you try a hex format reader?
    Or else you can go with "TI Raw Data"  option while saving the memory which is readable in notepad++.
    Please note the "TI Raw Data" option will be downloaded with the big-endian format.
    Thanks, Katta
