Part Number: TMDSCNCD280049C
Hi I use TMDSCNCD280049C + XDS100v3 + CCS8.3, got warning as below. but F28034 board is working. pls help to check the trouble. thank.
Please take a look at the infosheet for the control CARD here http://dev.ti.com/tirex/explore/node?node=AFgSu2yd6L-WzvosY-KOCA__gYkahfz__LATEST
Section 3.4 on page 4 has a table with specific jumper settings to enable the emulation from the docking station vs using the on-PCB XDS100v2. You'll need to check switches S1:A and S1.
Let me know if this resolves the issue.
Matthew
Alternatively, you could try and use the on-board XDS100v2 with the USB connection you see in on the CNCD board. Power will still need to be supplied from the docking station as you have already done.
Matt
