Part Number: TMS320F28377D
Other Parts Discussed in Thread: UNIFLASH,
Hello
I have a customer using the uniflash batch command tool to program the TMS320F28377D DSP.
It has been observed that validation fails when using the flash (-f) and verify (-v) commands together in the same command.
However, issuing a flash command and THEN a separate verify command seems to work as expected.
What is the recommended way of validating an image after it has been programmed? Is there a way to do this in one dslite.bat command, or should validating always be done in a separate command after flashing?
Munan
