CCS:TIDM-1001 Two-Phase Interleaved LLC Resonant Converter Kit Does Not Have PWM Waveform Output
Other Parts Discussed in Thread: TIDM-1001, TMDSCNCD28379D
I recently started researching the TIDM-1001 two-phase interleaved LLC resonant converter kit, writing the program to the C2000 real-time control MCU according to the reference design guide.
TMDSCNCD28379D. After repeated tests, when constructing 1 and constructing 2, there is no PWM waveform output, the protection code is all shielded, and there is still no PWM waveform output. After several days of research, I don't know where the problem is.
  • Hi Deagle,
    What do you mean by "when constructing 1 and constructing 2, there is no PWM waveform output"? You should first verify the PWM output in build 1. Have you seen the output before or you have never seen it previously? Theoretically you can just follow the user guide to run it unless there are something wrong in the kit or there are some procedures missing.
    Chen
  • Deagle,
    Checking back in to see if you were able to get the kit working or still having issues.  I'm going to mark as "TI Thinks Resolved" but if you have further questions, please reply back and it will alert us.
    Matthew
