TMS320F28379D: Simulink Matlab Value Increase decrease in steps
Part Number: TMS320F28379D
Other Parts Discussed in Thread: TI-CGT, CONTROLSUITE
Hello guys,
I want to slowly increase or decrease the current Value to a Input-value.
My minimum input should be -100 and my maximum 100. I want the current value to rise/fall by 0.05 for a step.
In theory it's very simple, but i dont know how to implement it to my simulink model
If (Input<Output)
Output - - 0.05;
if(Input>Output)
Output=Input;
else If  (Input>Output)
Output + + 0.05;
if(Input<Output)
Output=Input;
That's the path where i need it.
Best regards
Kevin
    This is more a modeling question than related to device.
    Please try connecting to our support at:
    I contacted the Support and get an suggestion for my problem.
    I tried it and now i become an error, i don't know how to fix.
    Here's the model from the Matlab support:
    And thats the error text:
    ### Build procedure for model: 'PWM3PHASE_V7' aborted due to an error.
    Error(s) encountered while building "PWM3PHASE_V7": ### Failed to generate all binary outputs.
    Do you know how to fix it ?
    Best regards
    Kevin
    Please provide full error log and attach model if possible.
  • ### Starting build procedure for model: PWM_3PHASE_DAB ### Generating code and artifacts to 'Model specific' folder structure
      Code Generation
      38
    Elapsed: 51 sec
    ### Generating code into build folder: U:\Bachelorarbeit\Launchpad\PWM3PHASE\PWM_3PHASE_DAB_ert_rtw
    Output port 5 of 'PWM_3PHASE_DAB/RS232-Receiver and Decoder' is not connected. [32 similar]
    Component:Simulink | Category:Block warning
    Source 'PWM_3PHASE_DAB/ADC-Subsystem/Input V ADC3' specifies that its sample time (-1) is back-inherited. You should explicitly specify the sample time of sources. You can disable this diagnostic by setting the 'Source block specifies -1 sample time' diagnostic to 'none' in the Sample Time group on the Diagnostics pane of the Configuration Parameters dialog box. [4 similar]
    Parameter precision loss occurred for 'Gain' of 'PWM_3PHASE_DAB/PWM-Subsystem/Subsystem/Gain2'. The parameter's value cannot be represented exactly using the run-time data type. A small quantization error has occurred. To disable this warning or error, in the Configuration Parameters > Diagnostics > Data Validity pane, set the 'Detect precision loss' option in the Parameters group to 'none'. [2 similar]
    ### Invoking Target Language Compiler on PWM_3PHASE_DAB.rtw ### Using System Target File: C:\Program Files\MATLAB\R2018b\rtw\c\ert\ert.tlc ### Loading TLC function libraries ### Generating TLC interface API for custom data . ### Initial pass through model to cache user defined code ### Caching model source code ............................................................................... ............................................................... ### Writing header file PWM_3PHASE_DAB_types.h ### Writing source file PWM_3PHASE_DAB.c . ### Writing header file PWM_3PHASE_DAB_private.h ### Writing header file PWM_3PHASE_DAB.h ### Writing header file DSP28xx_SciUtil.h ### Writing source file DSP28xx_SciUtil.c ### Writing header file rtwtypes.h . ### Writing header file rtGetNaN.h ### Writing source file rtGetNaN.c ### Writing header file rt_nonfinite.h ### Writing source file rt_nonfinite.c ### Writing header file rtGetInf.h . ### Writing source file rtGetInf.c ### Writing source file PWM_3PHASE_DAB_data.c ### Writing header file rtmodel.h ### Writing source file ert_main.c ### TLC code generation complete. .### Evaluating PostCodeGenCommand specified in the model
      Code Composer Studio Project
     1
    Elapsed: 0.882 sec
    ### Creating CCS Project at : U:\Bachelorarbeit\Launchpad\PWM3PHASE\PWM_3PHASE_DAB_ert_rtw\CCS_Project ### CCS project created successfully Open project in Code Composer Studio.
    ### Using toolchain: Texas Instruments C2000 Code Generation Tools v16.9.2 | gmake (64-bit Windows) ### Creating 'U:\Bachelorarbeit\Launchpad\PWM3PHASE\PWM_3PHASE_DAB_ert_rtw\PWM_3PHASE_DAB.mk' ... ### Building 'PWM_3PHASE_DAB': "C:\PROGRA~1\MATLAB\R2018b\bin\win64\gmake" -B -f PWM_3PHASE_DAB.mk all U:\Bachelorarbeit\Launchpad\PWM3PHASE\PWM_3PHASE_DAB_ert_rtw>cd . U:\Bachelorarbeit\Launchpad\PWM3PHASE\PWM_3PHASE_DAB_ert_rtw>if "" == "" ("C:\PROGRA~1\MATLAB\R2018b\bin\win64\gmake" -B -f PWM_3PHASE_DAB.mk all ) else ("C:\PROGRA~1\MATLAB\R2018b\bin\win64\gmake" -B -f PWM_3PHASE_DAB.mk ) C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=MW_c28xx_board.obj MW_c28xx_board.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=DSP28xx_SciUtil.obj DSP28xx_SciUtil.c "DSP28xx_SciUtil.c", line 114: warning: variable "k" was declared but never referenced C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=MW_c28xx_adc.obj MW_c28xx_adc.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=MW_c28xx_csl.obj MW_c28xx_csl.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=MW_c28xx_pwm.obj MW_c28xx_pwm.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=PWM_3PHASE_DAB.obj PWM_3PHASE_DAB.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=PWM_3PHASE_DAB_data.obj PWM_3PHASE_DAB_data.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=rtGetInf.obj rtGetInf.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=rtGetNaN.obj rtGetNaN.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=rt_nonfinite.obj rt_nonfinite.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=c2837xDBoard_Realtime_Support.obj C:/ProgramData/MATLAB/SupportPackages/R2018b/toolbox/target/supportpackages/tic2000/src/c2837xDBoard_Realtime_Support.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_CpuTimers.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CpuTimers.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_DefaultISR.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_DefaultISR.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_GlobalVariableDefs.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/source/F2837xD_GlobalVariableDefs.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_PieCtrl.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieCtrl.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_PieVect.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieVect.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_SysCtrl.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_SysCtrl.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 -s -v28 -ml --float_support=fpu32 --output_file=F2837xD_usDelay.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_usDelay.asm C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 -s -v28 -ml --float_support=fpu32 --output_file=F2837xD_CodeStartBranch.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CodeStartBranch.asm C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Dma.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Dma.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Adc.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Adc.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Gpio.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Gpio.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Ipc_Driver_Lite.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Ipc_Driver_Lite.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=profiler_Support.obj C:/ProgramData/MATLAB/SupportPackages/R2018b/toolbox/target/supportpackages/tic2000/src/profiler_Support.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=c2837xDSchedulerTimer0.obj C:/ProgramData/MATLAB/SupportPackages/R2018b/toolbox/target/supportpackages/tic2000/src/c2837xDSchedulerTimer0.c C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=1 -DTID01EQ=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DRT -DF28379D -DCPU1 -DBOOT_FROM_FLASH=0 -DMODEL=PWM_3PHASE_DAB -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IU:/Bachelorarbeit/Launchpad/PWM3PHASE -IU:/Bachelorarbeit/Launchpad/PWM3PHASE/PWM_3PHASE_DAB_ert_rtw -IU:/BACHEL~1/LAUNCH~1/PWM_3P~1 -IC:/PROGRA~1/MATLAB/R2018b/extern/include -IC:/PROGRA~1/MATLAB/R2018b/simulink/include -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2018b/rtw/c/ert -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2018b/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2018b/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/toolbox/target/shared/EXTERN~1/include --output_file=ert_main.obj ert_main.c "### Creating standalone executable "../PWM_3PHASE_DAB.out" ..." C:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 -z -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2018b/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/lib --stack_size=512 --warn_sections --heap_size=1024 --reread_libs --rom_model -m"PWM_3PHASE_DAB.map" -l"rts2800_fpu32.lib" --define F28379D --define CPU1 --define BOOT_FROM_FLASH=0 --define BOOT_USING_BL=0 --output_file=../PWM_3PHASE_DAB.out MW_c28xx_board.obj DSP28xx_SciUtil.obj MW_c28xx_adc.obj MW_c28xx_csl.obj MW_c28xx_pwm.obj PWM_3PHASE_DAB.obj PWM_3PHASE_DAB_data.obj rtGetInf.obj rtGetNaN.obj rt_nonfinite.obj c2837xDBoard_Realtime_Support.obj F2837xD_CpuTimers.obj F2837xD_DefaultISR.obj F2837xD_GlobalVariableDefs.obj F2837xD_PieCtrl.obj F2837xD_PieVect.obj F2837xD_SysCtrl.obj F2837xD_usDelay.obj F2837xD_CodeStartBranch.obj F2837xD_Dma.obj F2837xD_Adc.obj F2837xD_Gpio.obj F2837xD_Ipc_Driver_Lite.obj profiler_Support.obj c2837xDSchedulerTimer0.obj ert_main.obj C:/ProgramData/MATLAB/SupportPackages/R2018b/toolbox/target/supportpackages/tic2000/rtlib/IQmath_fpu32.lib C:/ProgramData/MATLAB/SupportPackages/R2018b/toolbox/target/supportpackages/tic2000/src/c2837xDPeripherals.cmd C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/lib/SFO_v8_fpu_lib_build_c28.lib C:/ProgramData/MATLAB/SupportPackages/R2018b/toolbox/target/supportpackages/tic2000/src/c28377D.cmd <Linking> "C:/ProgramData/MATLAB/SupportPackages/R2018b/toolbox/target/supportpackages/tic2000/src/c28377D.cmd", line 122: error: program will not fit into available memory. placement with alignment/blocking fails for section ".switch" size 0x40 page 0. Available memory ranges: RAMLS_PROG size: 0x3000 unused: 0x19 max hole: 0x18 error: errors encountered during linking; "../PWM_3PHASE_DAB.out" not built >> Compilation failure gmake: *** [../PWM_3PHASE_DAB.out] Error 1 U:\Bachelorarbeit\Launchpad\PWM3PHASE\PWM_3PHASE_DAB_ert_rtw>echo The make command returned an error of 2 The make command returned an error of 2 U:\Bachelorarbeit\Launchpad\PWM3PHASE\PWM_3PHASE_DAB_ert_rtw>An_error_occurred_during_the_call_to_make Der Befehl "An_error_occurred_during_the_call_to_make" ist entweder falsch geschrieben oder konnte nicht gefunden werden. ### Creating HTML report file PWM_3PHASE_DAB_codegen_rpt.html
    ### Build procedure for model: 'PWM_3PHASE_DAB' aborted due to an error.
    Error(s) encountered while building "PWM_3PHASE_DAB": ### Failed to generate all binary outputs.
    Component:Simulink | Category:Block diagram error
  • https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/171/PWM_5F00_3PHASE_5F00_DAB.7z
    The model is consuming all of the RAM available and more.
    Please consider increasing the RAM memory from linker command file or try to build the model for Flash by doing the following setting.
  • Thanks, it works. :)
