Part Number: TMS320F28075
Hi Champ,
The ADCINA1 has internal 50KOHM pulldown resistor, may I know how this resistor will affect the ADC result?
Anything need to take care will using this channel to sampling the signal?
Hi Champ,
Hi Huihuang,
If you have an ADC input driver with a high resistance (e.g. a voltage divider from a high voltage with no op-amp buffer) then the pull-down will form a voltage divider with the input, causing some gain error in the result.
If you drive the input with an op-amp, the error effect will generally be very small or negligible.
