Part Number: TMS320F28377D
Hi expert,
May I know if we have any method in CSS, using debug, compiler generated file or some other method to dig out the storage location of internal static variable?
Sheldon
Hi expert,
Sheldon
Hi Sheldon,
I am not sure what you mean by internal static variables..
These 4 sections below are usually the common sections where the static variables are stored.
Other memory locations and details can be got it sections 6.3.5 Specifying Where to Allocate Sections in Memory and 8.1.1 Sections of the below doc.
http://www.ti.com/lit/ug/sprui04b/sprui04b.pdf
The linker command file specifies which physical memory these sections like .bss etc are allocated to .
The .map file generated as part of the code compile can give details on the static variables and the sections.
Regards.
